TrelloConnector
Accesses the Trello web service to create, update, archive, or list the contents of Trello Boards, Lists, and Cards.
Jump to Configuration
  • Add workspace attributes to a Board or Card on your account
  • Obtain Board or Card information to use in your workspace as attributes
  • Manage your Trello account by Creating, Updating, and Deleting Trello Boards, Lists and Cards
  • Create complex or duplicated Trello Boards, Lists, and Cards
  • Chain TrelloConnectors to perform multiple operations using attributes from different accounts, Boards, Lists, or Cards
The TrelloConnector uses your Trello account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the project management service.
Depending on your choice of actions, it will create, update, archive, or list information from Trello Boards, Lists, and Cards. On Create, Update, and List actions, information from the Trello objects can be added to the output features. On Archive actions, basic identification information from the archived Trello object is added to the output attribute.
The remaining parameters available depend on the value of the Request > Action parameter. Parameters for each Action are detailed below.
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Trello account
Aliases
History Released FME 2019.0
Search for all results about the TrelloConnector on the FME Community.
