SurfaceFootprintReplacer
Replaces the geometry of a feature with a planar representation of the feature's shadow.
Output features with replaced shadow geometries.
Features with null geometries are rejected.
Shadow Mode |
Overhead Shadow: The shadows are obtained from a light source directly above the features. The shadows will have a Z coordinate specified by the Elevation parameter. Drop Shadow: The shadows are obtained from a light source located in a direction specified by the X, Y, Z parameters. The shadows will have a Z coordinate specified by the Elevation parameter. Perpendicular Shadow: The shadows are obtained from a light source located in a direction specified by the X, Y, Z parameters, but are cast onto a plane perpendicular to the direction of the light source. Each feature's shadow is located near the original feature, so the shadows may not all lie on the same plane. |
Elevation |
The value that will be used as the Z coordinate in the output shadow features. This parameter is not used when the Shadow Mode is Perpendicular Shadow. |
X, Y, Z |
Coordinates representing the direction of the light source projecting the shadow. The light source is considered to be an infinite distance away. The Z coordinate cannot be 0. |
Dialog Options - Tables
Keywords: SurfaceFootprintGenerator
