RasterObjectDetectionModelTrainer
Trains a custom raster object detection model based on the positive and negative samples.
Trains a custom raster object detection model based on the positive and negative datasets. The resulting model file can be used to detect the desired object using RasterObjectDetector. For convenience, you may get the input datasets from RasterObjectDetectorSamplePreparer that takes multiple positive samples and a number of negative samples for preparation. Or you may generate artificial samples using RasterObjectDetectorSampleGenerator (note that artificially generated samples usually perform worse than hand-picked ones)
Note that the transformer calls an external (opencv_traincascade) process to perform the model training. At the moment, if translation is suspended or stopped, the opencv_traincascade process is going to remain running and will need to be killed manually.
The transformer accepts any feature but the contents are largely ignored. A possible input would be the feature output from RasterObjectDetectorSamplePreparer which will contain a number of input parameters required for translation.
This port returns the original feature and the _out_detection_model_name attribute, containing the path to the produced custom detection model.
This port returns a feature with all its original contents and an fme_rejection_message containing the error message if any occur.
Positive Samples File |
Positive .vec file. Can be produced by either RasterObjectDetectorSamplePreparer or RasterObjectDetectorSampleGenerator. See their documentation for further details. Alternatively, this file can be produced by manually calling the opencv_createsamples app. |
Background Description File |
Negative samples description file. Must contain absolute paths to your negative sample images, one image per line of the file. Can be produced by either RasterObjectDetectorSamplePreparer or RasterObjectDetectorSampleGenerator. See their documentation for further details. |
Number of Positive Samples |
Number of positive samples contained in the input Positive Samples File. |
Number of Negative Samples |
Number of negative samples contained in the input Background Description File. |
Training Model Type |
Sample Width & Height |
Width and Height of the resulting detection window. Must be the same as the size of positive samples specified in the input .vec file. These parameters can be acquired from RasterObjectDetectorSamplePreparer or RasterObjectDetectorSampleGenerator. |
Value Buffer Size |
Size of buffer for feature values in Mb (Megabytes). The more memory is given, the faster the training process is going to be. Ensure that the combined memory specified for Value and Index buffer sizes does not exceed the total system memory. |
Index Buffer Size |
Size of buffer for feature indices in Mb (Megabytes). The more memory is given, the faster the training process is going to be. Ensure that the combined memory specified for Value and Index buffer sizes does not exceed the total system memory. |
Advanced |
Intermediate Working Directory |
Detection Model |
Path to the file which will contain the trained detection model. |
Boosted Classifier Parameters |
From OpenCV: A common machine learning task is supervised learning. In supervised learning, the goal is to learn the functional relationship F: y = F(x) between the input x and the output y. Predicting the qualitative output is called classification, while predicting the quantitative output is called regression. You can read more about Boosting parameters in the official OpenCV Documentation and OpenCV Boosting Documentation |
Dialog Options - Tables
