RandomNumberGenerator
Generates a uniformly distributed random number.
The random number is x, where Minimum Value <= x <= Maximum Value.
RandomNumberGenerator generates random numbers using the Tcl
rand()
function. The numbers generated by this function may not be considered truly random, becauserand()
requires an initial seed value, which determines the sequence of numbers that is generated. There are no more than 2^31 possible random number sequences, and these sequences repeat after 2^31 times. The same seed value, used repeatedly, generates the same numbers. Additionally, the sequence, by design, never produces the same number twice in a row.
Note: Feature order may change in relation to other output ports. Feature order per port is maintained.
The dynamic <Rejected> port appears when a parameter is set to a non-literal value that might make processing impossible.
For example, if a numeric parameter such as Line Width, Count Start, or Decimal Places is set to an expression, attribute value, or user parameter, it is possible to pass in a non-numeric value that cannot be used. Decimal Places = Cat cannot be processed, so the feature will be output via this port.
Rejected features will have an fme_rejection_code attribute explaining the reason for rejection.
Minimum Value | Specify the minimum value that can be generated. |
Maximum Value | Specify the maximum value that can be generated. |
Decimal Places | The random number will be rounded to the number
of digits specified in the Decimal Places parameter. Note that in general, when the Minimum Value and Maximum Value is specified in an exponential form (for example, "1.0e+25"), Decimal Places refers to the number of decimal places in the exponential form. If Minimum Value or Maximum Value have more decimal places than the Decimal Places requested for the result, the actual minimum value used will be rounded up and the actual maximum value used will be rounded down to the requested decimal places. This is to ensure that the generated random number will always fall between the Minimum Value and the Maximum Value. |
Generated Number |
Name the attribute to contain the generated number. |
Dialog Options - Tables
