NetworkTopologyCalculator
Finds the connected lines that belong to the same network graph.
Network Topology in FME
In order to successfully generate a network topology, some conditions must be met.
  • Lines must touch (be snapped) at an end vertex - first or last.
  • Lines must be split at junctions. The TopologyBuilder can automate this process, but will not consider z-values (and so may not produce correct results for overpasses/underpasses, for example.)
  • A junction at an interior vertex (not an end vertex) produces a complex edge, which is not supported.
Dialog Options - Tables
Transformer History
This transformer has been renamed from NetworkTopologyBuilder.
Keywords: Network, NetworkTopologyBuilder
Keywords: network networktopologybuilder
