FMEServerJobSubmitter
Submits FME jobs to be run on an FME Server. A job consists of a workspace (housed within a repository on an FME Server) together with values for each of its published parameters. This transformer submits one job per feature which enters it. Any published parameters of the server workspace will be given values as specified in the transformer, or taken from attributes of the feature which enters it.
The FMEServerJobSubmitter submits jobs via the FME Server REST API and does not make use of the transformation services.
Dependencies
This transformer requires an FME Server connection.
Connection
You can connect to an FME Server in one of the following ways:
Note: You can click the Status hyperlink to ensure that the FME Server connection has been successfully established.
Submission Mode
Job Parameters
Advanced
Dialog Options - Tables
Transformer History
This transformer was previously named the ServerJobSubmitter.
Keywords: ServerJobSubmitter
