FilenamePartExtractor
Extracts specified parts of a filename path and returns the results as string attributes.
Example
For example, the path
C:\WINNT\Profiles\user\Desktop\roads.shp
would be extracted as follows:
Folder Path | C:\WINNT\Profiles\user\Desktop\ |
Full Filename | roads.shp |
Filename Root | roads |
Filename Extension | shp |
Folder Name | Desktop |
When parsing the path, both backslashes and forward slashes are handled as separators, regardless of operating system.
Source Filename |
The attribute that holds the full filename and path. |
Folder Path |
If specified, this attribute will contain the full folder path of the Source Attribute, excluding the Full Filename. |
Full Filename |
If specified, this attribute will contain the full filename (including extension) of the Source Attribute. |
Root Filename |
If specified, this attribute will contain the root filename (without extension) of the Source Attribute. |
If specified, this attribute will contain the extension of the file specified in the Source Attribute. |
Folder Name |
If specified, this attribute will contain the folder name of the file specified in the Source Attribute. |
Dialog Options - Tables
