DMSCalculator
Calculates degrees, minutes, and seconds (DMS) from a decimal degrees value provided as an attribute.
Jump to Configuration
  • Calculating the DMS (degrees, minutes, seconds) equivalent of latitude and longitude decimal degree values.
The DMSCalculator receives any feature with an attribute containing a valid decimal degree value, and converts that value to degrees, minutes, and seconds. The results are added as attributes to the output feature.
If an invalid (for example, non-numeric) value is received, the translation will fail.
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
Search for all results about the DMSCalculator on the FME Community.
