BoundingBoxReplacer
Replaces the geometry of the feature with either its two-dimensional bounding box, its two-dimensional minimum oriented bounding box, or its three-dimensional bounding cube.
If a feature’s bounding box has zero area, it will become a line or a point.
Replace With |
Choose 2D Bounding Box (which means the axis-aligned or rectilinear bounding box), 2D Oriented Bounding Box, or 3D Bounding Cube. If a 3D Bounding Cube is chosen but the original geometry is 2D, a 2D Bounding Box will be created instead. |
Long Side Length | Name the attribute to contain the calculated length of the longest side of the bounding box or cube. |
Short Side Length | Name the attribute to contain the calculated length of the shortest side of the bounding box or cube. |
Example
- To accumulate the bounding box of a number of features, use the BoundingBoxAccumulator.
- To retrieve the bounds of a feature into attributes, use the BoundsExtractor.
- To replace the geometry of a feature with a box whose values come from attributes, use the 2DBoxReplacer.
- Point Clouds: the BoundingBoxReplacer does not consider individual points within a point cloud feature. To generate a 2D Oriented Bounding Box from point cloud points, use a PointCloudToPointCoercer prior to the BoundingBoxReplacer, setting the Output Geometry parameter to Single Multipoint.
Dialog Options - Tables
Keywords: MBR "minimum bounding rectangle" neatline "envelope oriented" "bounding box"
