AzureServiceBusConnector
Connects to Azure’s Service Bus using the Azure Service Bus SDK.
Jump to Configuration
  • Receive and send messages from a queue or topic
  • Interoperability with Big Data analytics platforms
The AzureServiceBusConnector connects to Azure’s Service Bus using the Azure Service Bus SDK.
Service Bus uses the AMQP 1.0 protocol. The connector supports sending and receiving messages.
More information about Service Bus can be found in the official Microsoft documentation.
The remaining parameters available depend on the value of the Request > Action parameter. Parameters for each Action are detailed below.
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Microsoft Azure Account with the Service Bus Service
Aliases
History Released FME 2019.2
Search for all results about the AzureServiceBusConnector on the FME Community.
