AzureQueueStorageConnector
Accesses the Azure Queue Storage service to send or receive messages.
Jump to Configuration
  • Aggregation of data from queues and other message streams
  • Trigger an action from a message
The AzureQueueStorageConnector uses your Azure Storage account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the queue storage service.
  • The queue storage service xml encodes and decodes messages in utf-8 by default
The remaining parameters available depend on the value of the Action > Action parameter. Parameters for each Action are detailed below.
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Azure Storage account
Aliases MicrosoftAzureQueueStorageConnector
History Released FME 2019.0
Search for all results about the AzureQueueStorageConnector on the FME Community.
