AttributeKeeper
Removes all attributes and list attributes, except the specific ones you specify to be retained.
Jump to Configuration
  • Cleaning up features with large numbers of unnecessary attributes
Once connected to input features, the AttributeKeeper provides pick lists (one for attributes and one for list attributes) for you to choose which attributes to retain. All other attributes are removed, and the modified features are output.
Geometry and FME attributes are not removed.
Format attributes will be removed whether exposed or not . Exposed FME attributes will simply be hidden - not removed permanently.
  • If the number of attributes you want to keep is greater than the number of attributes you want to remove, consider using the AttributeManager.
  • Use the AttributeManager to remove selected individual attributes from a feature.
  • Use the BulkAttributeRemover to remove all attributes that match a pattern.
  • To keep a Format attribute, expose it first, either in the reader or by using the AttributeExposer
  • If you choose to keep a list element attribute, for example member{0}.type, it won’t appear under the transformer unless this element has already been exposed. See Exposing List Attributes for more information.
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases ListKeeper
History
Search for all results about the AttributeKeeper on the FME Community.
