AreaCalculator
Calculates the area of a polygonal object and stores the value in an attribute. The area is calculated in square map units, whatever they are.
The type of area calculation that is performed is chosen by the Type parameter.
Note: Feature order may change in relation to other output ports. Feature order per port is maintained.
General
Output Attribute Name
Dialog Options - Tables
Keywords: Euclidean
