ArcPropertyExtractor
                                            Sets the given attributes to the properties of an arc geometry. This transformer works on a single feature at a time.
Features with arc geometry.
Features with given attributes set to the properties of the arc geometry.
Note: Feature order may change in relation to other output ports. Feature order per port is maintained.
Output Attribute Names
Attribute name that is set to the length of the primary radius for the ellipse upon which the arc is based.
Attribute name that is set to the length of the secondary radius for the ellipse upon which the arc is based.
Attribute name that is set to the rotation of the ellipse that defines the arc. The rotation angle specifies the angle in degrees from the horizontal axis to the primary axis in a counterclockwise direction.
Attribute name that is set to the parametric angle of the start point of the arc, in degrees.
Attribute name that is set to the parametric sweep angle of the arc, in degrees.
Attribute name that is set to the x coordinate value for the arc’s start point
Attribute name that is set to the y coordinate value for the arc’s start point
Attribute name that is set to the z coordinate value for the arc’s start point
Attribute name that is set to the x coordinate value for the arc’s end point
Attribute name that is set to the y coordinate value for the arc’s end point
Attribute name that is set to the z coordinate value for the arc’s end point
Attribute name that is set to the X coordinate of the center of the ellipse. If not specified, the first coordinate of the feature is used.
Attribute name that is set to the Y coordinate of the center of the ellipse. If not specified, the first coordinate of the feature is used.
Attribute name that is set to the Z coordinate of the center of the ellipse. If not specified, the first coordinate of the feature is used.
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
