Unfolded Data: Add Web Connection
Unfolded Data Authentication
Using the Unfolded Data Reader/Writer requires an Unfolded Web Connection. Using this format always requires authenticated access.
Note: Unfolded API tokens are only available for Enterprise-level accounts.
Unfolded Data Web Connections require the refresh token for your Unfolded Studio account:
  • To retrieve your refresh token, visit https://studio.unfolded.ai/tokens.html.
  • Note that once a refresh token has been used to generate an Unfolded Web Connection, it will no longer be valid. The web connection will exchange refresh tokens approximately once every 24 hours.
To define a new connection from the Unfolded Connection parameter:
  • Select Add Web Connection. See database-specific parameters below, as well as the section To Use a Web Connection in a Workspace in Using Web Connections. The new connection can be made visible only to the current user, or can be shared among multiple users.
Note: To select an existing, previously defined connection, see the section Reusing a Web Connection in Using Web Connections
Web Service
Unfolded (safe.Unfolded)
Connection Name
Enter a name for the new connection.
Unfolded (safe.Unfolded) Parameters
Refresh Token
To retrieve your refresh token, visit https://studio.unfolded.ai/tokens.html. Note that once a refresh token has been used to generate an Unfolded Web Connection, it will no longer be valid.
Unfolded API Client ID
This is the client ID which will be used to make refresh token exchange requests. This value should be set to the default Unfolded REST API Client ID provided in the web service definition.
