OGC CSW (Catalogue Services for the Web) Reader/Writer
FME Format Type Identifier
OGC_CSW
Reader/Writer
Both
FME can retrieve and modify metadata information from an OGC CSW compliant server.
The OGC CSW Reader/Writer adheres to version 2.0.2 of the OpenGIS Catalogue Service Implementation Specification, on the OpenGIS Consortium website.
OGC CSW Product and System Requirements
Format
Product
Operating System
Reader/Writer
FME Desktop License
FME Server
FME Cloud
Windows 64-bit
Linux
Mac
Reader
Available in FME Professional Edition and higher
Yes
Yes
Yes
Yes
Yes
Writer
Yes
Yes
Yes
Yes
Yes
Overview
OGC CSW is an OpenGISĀ® Implementation Specification. The OGC CSW specification defines the HTTP operations listed below.
HTTP Operations
Supported?
DescribeRecord
No
GetCapabilities
Yes
GetDomain
No
GetRecordById
No
GetRecords
Yes
GetRepositoryItem
No
Harvest
No
Transaction
Yes
The Reader supports GetCapabilities and GetRecords operations; the Writer supports GetCapabilities and Transaction operations in this implementation.
Reader Overview
The CSW reader queries a CSW compliant server for catalogue records with a search.
Every record returned from the search is represented by the CSW reader with a single feature type.
The CSW reader currently supports searching for records using either text-based and/or bounding-box-based methods. Please refer to the Search Settings for information about specifying a search text, or Use Search Envelope for information about specifying a bounding box. The search text provided by the user will be the feature type for all the records returned in that search. If the search text was not provided, the feature type will be set to CSW Records.
Writer Overview
The CSW writer can perform transactions on a CSW compliant server.
A transaction request can insert, update, or delete catalogue records on the CSW server.
The CSW writer currently supports 2 feature types: CSW_Records and Other.
For CSW servers that use the csw:Record schema to store catalogue records, CSW_Records feature type should be used to perform transactions on the server. For all other types of records, use the Other feature type. The record will be retrieved from the record_xml_frag attribute on the Other features.
