Microsoft Access (JDBC) Reader/Writer
FME Format Type Identifier
MSACCESS_JDBC_2
Reader/Writer
Both
Format Type
Database
Typical File Extensions
.mdb, .accdb
This format allows FME to access attribute data held in Microsoft Access database tables.
Microsoft Access (JDBC) Product and System Requirements
Format
Product
Operating System
Reader/Writer
FME Desktop License
FME Server
FME Cloud
Windows
Linux
Mac
Reader
Available in FME Professional Edition and higher
Yes
Yes
64-bit: Yes
Yes
Yes
Writer
Yes
Yes
64-bit: Yes
Yes
Yes
The performance of this format is dependent on the amount of memory allocated to the Java Virtual Machine (JVM). The following environment variable allows you to specify memory available to Java Plugins:
  • FME_JVM_MIN_HEAP_SIZE: Initial heap size for initializing the JVM. If unset, the default value is 1024K.
This variable must be set in multiples of 1024 and greater than 1 MB. To indicate kilobytes, megabytes, or gigabytes, append k or K, m or M, or g or G, respectively. For example, any of these values is acceptable:
6291456
6144k
6m
  • FME_JVM_MAX_HEAP_SIZE: Maximum heap size for initializing the JVM. If unset, the default value is 16384K.
This variable must be set in multiples of 1024 and greater than 2 MB. To indicate kilobytes, megabytes, or gigabytes, append k or K, m or M, or g or G, respectively. For example, any of these values is acceptable:
83886080
81920k
80m
Note: To pass additional parameters used by FME to the Java Virtual Machine, use the JAVA_TOOL_OPTIONS environment variable.
Workbench Reader Overview
Click the Reader Parameters button and establish a Microsoft Access database connection.
Workbench Writer Overview
Click the Writer Parameters button and establish a Microsoft Access database connection.
The Microsoft SQL Server writer module stores attribute records into a live relational database. The Microsoft SQL Server writer provides the following capabilities:
  • Transaction Support: The Microsoft SQL Server writer provides transaction support that eases the data loading process. Occasionally, a data load operation terminates prematurely due to data difficulties. The transaction support provides a mechanism for reloading corrected data without data loss or duplication.
  • Table Creation: The Microsoft SQL Server writer uses the information within the workspace to automatically create database tables as needed.
FME Community
Search for articles about Microsoft Access JDBC.
