Actian Ingres Non-Spatial User Attributes
Readers: For information on the parameters in this dialog that are common to all readers, see:
Writers: For information on the parameters in this dialog that are common to all writers, see:
User attributes for this format are defined below.
Name The name of the field to be written.
Type
This format supports the following field types.
boolean
Represents a Boolean value.
byte
Represents a fixed-length binary object.
char
Represents a fixed-length character string.
date
Represents date data.
See Standard FME Date/Time Format.
decimal
Represents a decimal number with maximum precision of 39.
float4
Represents a 32-bit (4-byte) double-precision number.
float8
Represents a 64-bit (8-byte) double-precision number.
int1
Represents a 8-bit (1-byte) signed integer.
int2
Represents a 16-bit (2-Byte) signed integer.
int4
Represents a 32-bit (4-byte) signed integer.
int8
Represents a 64-bit (8-byte) signed integer.
longbyte
Represents a Binary Large Object (BLOB).
longnvarchar
Represents a variable length Unicode Character Large Object (CLOB).
longvarchar
Represents a variable-length Character Large Object (CLOB).
money
Represents a number with two decimal places of precision in the range -999,999,999,999.99 to 999,999,999,999.99.
nchar
Represents a fixed-length Unicode character string.
nvarchar
Represents a variable-length Unicode character string.
time
This type is used to represent time data with an accuracy of up to 1 second.
timestamp
This type is used to represent date and time data with an accuracy of up to 1 microsecond.
timestamptz
This type is used to represent date and time data with time zone information and an accuracy of up to 1 microsecond.
timetz
This type is used to represent time data with time zone information with an accuracy of up to 1 second.
varbyte
Represents a variable-length binary object.
varchar
Represents a variable-length character string.
Index
The types of indexes and constraints to create for the column.
Indexes and constraints are created only if the table is created. Each index and constraint contains only one column.
The valid values for the column type are listed below:
PrimaryKey: Applies primary key constraint.
UniqueNotNull: Applies non-nullable and unique constraints
NotNull: Applies non-nullable constraint.
