Esri Geodatabase Quick Facts
About Quick Facts Tables
Esri Geodatabase Geometry Support
Format Type Identifier
ESRI_MOBILE_GEODATABASE – Esri Mobile Geodatabase
GEODATABASE_SDE – Esri Geodatabase (ArcSDE Geodb)
GEODATABASE_FILE – Esri Geodatabase (File Geodb)
GEODATABASE_SDE_RASTER_DATASET – Esri Geodatabase (ArcSDE Geodb Raster Dataset)
GEODATABASE_FILE_RASTER_DATASET – Esri Geodatabase (File Geodb Raster Dataset)
GEODATABASE_SDE_RASTER_CATALOG – Esri Geodatabase (ArcSDE Geodb Raster Catalog)
GEODATABASE_FILE_RASTER_CATALOG – Esri Geodatabase (File Geodb Raster Catalog)
GEODATABASE_SDE_MOSAIC_DATASET – Esri Geodatabase (ArcSDE Geodb Mosaic Dataset)
GEODATABASE_FILE_MOSAIC_DATASET – Esri Geodatabase (File Geodb Mosaic Dataset)
Reader/Writer
Both
Licensing Level
Format Licensing Level Available On
Professional Edition
Win 64-bit
Win 64-bit
Win 64-bit
Mac
Win 64-bit
Esri Edition
Win 64-bit
Esri Edition
Win 64-bit
Esri Edition
Win 64-bit
Esri Edition
Mac
Win 64-bit
Esri Geodatabase (Personal Geodb) Reader
Please see the linked topics for information about the new 64-bit reader.
Win 64-bit
Dependencies
  • Esri ArcGIS Server 10.1 or newer (64-bit Geodatabase)
  • Esri ArcGIS Pro 2.7 or newer (Mobile Geodatabase)
FME and ArcGIS must both be running on 64-bit machines.
Dataset Type
  • None (ArcSDE)
  • File (Mobile Geodatabase)
  • Folder (File-based)
Feature Type
Feature Class name
Typical File Extensions
  • Geodatabase: .gdb
  • Mobile Geodatabase: .geodatabase
Automated Translation Support
Yes
User-Defined Attributes
Yes
Coordinate System Support
Yes
Generic Color Support
No
Appearance Support (Surfaces Only)
Yes
Spatial Index
Always
Schema Required
Yes
Transaction Support
Yes
Geometry Type
geodb_type
Encoding Support
Yes
Geodatabase Raster Support
Band Interpretations Red8, Red16, Green8, Green16, Blue8, Blue16, Gray8, Gray16, Int8, UInt8, Int16, UInt16, Int32, UInt32, Real32, Real64
Palette Key Interpretations UInt8, UInt16
Palette Value Interpretations RGB24
Nodata Value Yes
Cell Origin (x, y) 0.5, 0.5
Rotation Support No
GCP Support No
World File Support No
TAB File Support No
Note: Esri Geodatabases can store rasters as raster datasets, raster catalogs, and raster mosaics. FME supports reading raster datasets and raster catalogs. In addition, FME supports reading mosaic datasets either as a single mosaicked raster through a raster dataset reader, or as multiple-source rasters through a raster catalog reader. Writing is supported for raster datasets but not for raster catalogs or mosaic datasets. Finally, raster support is limited to File Geodatabases and Enterprise Geodatabases.
