Webhook Triggered
The Webhook trigger receives JSON and other data in the body of an HTTP POST request message.
For the Webhook to receive a JSON-formatted request body, you must configure the message schema to match the expected data (see Output Keys, below).
The Webhook trigger has two output ports. The success port (✔) can send a message if the trigger initiates successfully. The failure port (x) can send a message if the trigger fails to initiate.
Output Keys
