FME Server Topic Notified
The FME Server Topic Notified trigger sends messages generated from FME Server Notification Service Topics.
The FME Server Topic Notified trigger has two output ports. The success port (✔) can send a message if the trigger fails. The failure port (x) can send a message if the trigger succeeds.
Note: Use the Topic trigger only to initiate a workflow, or a portion of a workflow. It is otherwise not necessary to explicitly define topics for a workflow to run.
Output Keys
