Notify an FME Server Topic
You can designate FME Server Notification Service Topics to receive messages.
The Notify FME Server Topic external action has two output ports. The success port (✔) can send a message if the topic is notified successfully. The failure port (x) can send a message if the notification fails.
Note: Use the FME Server Topic external action only to terminate a workflow, or a portion of a workflow. It is otherwise not necessary to explicitly define FME Server topics for a workflow to run.
Note: When Retry settings are configured, the failure port renders with a Retry Configured (⟳) icon.
Output Keys
Retry
