RasterTiler
Jump to Configuration
- Dividing a raster into smaller rasters
- Reversing the action of a RasterMosaicker
- Tiling rasters to match the extents of additional datasets to enable group processing
- Tiling data to facilitate parallel processing
The RasterTiler accepts raster features, and divides them into smaller tiles according to the parameter selections.
Tile size can be defined by specifying tile dimensions in cells/pixels, or by specifying the number of tiles to create, both vertically and horizontally.
In either case, the tiles are measured from the upper-left origin (0,0) position. If tiling by Tile Size, the origin can be offset (Seed Column and Seed Row).
If the specified tile size results in partial (smaller) tiles along the right or lower edge, the Force Equal Sized Tiles option can pad smaller tiles with cells to match the full tile size.
Attributes may be added to the output tiled raster features, including an original raster index, row and column positions, and tile counts.
RasterTiler or Tiler?
The Tiler transformer also tiles rasters, and may be appropriate if you wish to tile based on ground coordinates instead of pixels or tile number division. This table compares the two:
Type of data accepted |
All types |
Raster only |
Tile size units |
Ground coordinates |
Pixel coordinates |
Tile row numbering (0, 1,...) |
Selectable |
Top to bottom |
Supports forcing equal-size tiles |
Yes |
Supports raster index attribute |
Yes |
Supports number of horizontal/vertical tiles attribute |
Yes |
Example: Tiling a raster by tile size
In this example, we will tile a single orthophoto, by Tile Size. Note that the original image is 1600 by 1000 pixels.
The raster is routed into a RasterTiler.
In the parameters dialog, we choose Tile Size, and set the size to 400 by 400 cells (pixels).
This will produce four tiles across, exactly divided into the original 1600 pixels in width. It will produce three tiles vertically, but the lowest row will be partial (400 does not divide into 1000 equally). By turning on Force Equal Sized Tiles (Yes), the lowest row will be padded to produce full size tiles.
Twelve tiles are output, as shown here with their extents overlaid in pink. Note the new attributes which indicate the source raster, the number of rows and columns produced by the tiling operation, and this raster’s position. Row and column counts start from zero (0).
The lowest row has been padded with empty cells to match the defined tile size.
Example: Tiling a raster by number of tiles
In this example, we will tile a single orthophoto, using Number of Tiles. Note that the original image is 1600 by 1000 pixels.
In the parameters dialog, we choose Number of Tiles and set both the horizontal and vertical number to 3.
Nine tiles are output, shown here with their extents overlaid in yellow. The tile size is determined by dividing the dimensions of the original raster by the defined number of horizontal and vertical tiles.
When the division of number of tiles into the dimension produces partial cells/pixels, the number will be rounded up. In this case, 1600 width divided by 3 tiles = 533.33. The tiles are created as 534, 534, 532. If we had turned on Force Equal Sized Tiles, two columns of blank cells would be padded on the right-hand tiles.
Choosing a Raster Transformer
Raster Transformers
Working with Rasters
These transformers generally apply to whole rasters.
RasterCellOriginSetter
Sets the cell origin point within cells in a raster.
RasterConvolver
Applies a convolution filter (sometimes called a kernel or lens) to raster features and outputs the results.
RasterExpressionEvaluator
Evaluates expressions on each cell in a raster or pair of rasters, including algebraic operations and conditional statements.
RasterExtentsCoercer
Replaces the geometry of input raster features with a polygon covering either the extents of a raster or the extent of data within a raster.
RasterGCPExtractor
Extracts Ground Control Point (GCP) coordinate system and point values from a raster feature and exposes them as attributes.
RasterGCPSetter
Sets Ground Control Points (GCPs) on a raster, pairing cell positions with known coordinates.
RasterGeoreferencer
Georeferences a raster by either known corner coordinates or origin, cell size, and rotation.
RasterHillshader
Generates a grayscale shaded relief representation of terrain, based on elevation values.
RasterInterpretationCoercer
Alters the interpretation type of rasters, including all bands, and converts cell values if necessary.
RasterMosaicker
Merges multiple raster features into a single raster feature.
RasterPropertyExtractor
Extracts the geometry properties of a raster feature and exposes them as attributes.
RasterPyramider
RasterRegisterer
Transforms an image to minimize its difference with another.
RasterResampler
Resamples rasters, based on specified output dimensions, cell size in ground units, or percentage of original, and interpolates new cell values.
RasterRotationApplier
Rotates a raster feature according to its rotation angle property, interpolating new cell values, updating all other affected raster properties, and producing an output raster feature with a rotation angle of zero.
RasterSharpener
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
RasterSubsetter
Clips raster features using pixel bounds instead of ground coordinates, and optionally adds cells around the perimeter.
RasterTiler
RasterToPolygonCoercer
Creates polygons from input raster features. One polygon is output for each contiguous area of pixels with the same value in the input raster.
WebMapTiler
Creates a series of image tiles that can be utilized by web mapping applications such as Bing™ Maps, Google Maps™, or Web Map Tile Service. This is done by resampling rasters to various different resolutions and then splitting them into tiles.
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
These transformers generally control the flow of features in a workspace.
RasterCheckpointer
RasterConsumer
RasterExtractor
Serializes the geometry of a raster feature into a Blob attribute, encoding the contents according to a choice of common binary raster formats.
RasterNumericCreator
Creates a numeric raster of specified size and resolution, with default cell values.
RasterReplacer
Decodes a binary attribute containing encoded rasters stored as Blobs, replacing the feature’s geometry with the decoded raster.
RasterRGBCreator
Creates a color raster feature of specified size, resolution, and interpretation type, with default cell values.
RasterSelector
Selects specific bands and palettes of a raster for subsequent transformer operations.
Vectors and Rasters
These transformers generally involve using rasters and vector data together.
ImageRasterizer
Creates a raster representation of vector or point cloud input features, using the fme_color attribute over a solid background fill for vector features. Point clouds may be rendered using their color or intensity components.
NumericRasterizer
Creates a numeric raster representation of vector or point cloud input features, where cell values are taken from the z coordinates of the input features and overlaid on a uniform background.
MapnikRasterizer
Generates a raster from input vector and raster features, with fine control over symbolization and labeling, using the Mapnik toolkit.
PointCloudOnRasterComponentSetter
PointOnRasterValueExtractor
RasterDEMGenerator
VectorOnRasterOverlayer
Rasterizes vector or point cloud features onto an existing raster. For vector features the fme_color attribute sets pixel color, and point clouds may be rendered using their color or intensity components.
Input
Tiles
The tiles produced according to the parameter selections.
<Rejected>
INVALID_RASTER_NO_BANDS
INVALID_GEOMETRY_DEGENERATE
INVALID_PARAMETER_NUMBER_OF_ROWS
INVALID_PARAMETER_NUMBER_OF_COLUMNS
INVALID_PARAMETER_SEED_ROW
INVALID_PARAMETER_SEED_COLUMN
INVALID_PARAMETER_NUMBER_OF_HORIZONTAL_TILES
INVALID_PARAMETER_NUMBER_OF_VERTICAL_TILES
Tile Size
Tile Size or Number of Tiles
Choose how the input raster should be split:
Tile Size: define the size in vertical and horizontal number of pixels
Number of Tiles: Divide the raster into a fixed number of tiles
Number of Columns (cells)
If tiling by Tile Size, the number of cells (pixels) to include in each tile horizontally. Must be greater than 0.
Number of Rows (cells)
If tiling by Tile Size, the number of cells (pixels) to include in each tile vertically. Must be greater than 0.
Seed Column
If tiling by Tile Size, specify the starting location to start tiling. Default is (0,0) - (Seed Column, Seed Row) - which is the upper-left corner of the raster.
Seed Row
Number of Horizontal Tiles
If tiling by Number of Tiles, the desired number of tiles to be created horizontally. Must be an integer greater than 0.
Number of Vertical Tiles
If tiling by Number of Tiles, the desired number of tiles to be created vertically. Must be an integer greater than 0.
Equal Sized Tiles
Controls behavior when the raster size is not a multiple of the requested tile size or number of tiles.
No: Tiles on the right or bottom edge of the raster may be smaller than other tiles.
Yes: All tiles will be the same size.
Tile extents that exceed the raster will be padded with the Nodata value if one is set on the band; if no Nodata value is set, RGB rasters will have an alpha band added to identify the padding regions.
Attributes
Raster Index Attribute
Name the attribute to be added to each output tile that identifies which raster it was created from.
This index is zero-based, so all tiles created from the first input raster will have a value of 0, all tiles created from the second input raster will have a value of 1, and so on.
Tile Column Attribute
Name the attribute to be added to each output tile that identifies that tile’s column position, starting from 0.
Tile Column 0, Tile Row 0 corresponds to the upper-left tile.
Tile Row Attribute
Name the attribute to be added to each output tile that identifies that tile’s row position, starting from 0.
Number of Horizontal Tiles Attribute
Name the attribute to be added to each output tile that records the total number of tiles produced horizontally by the tiling operation on the input raster.
Attribute
Name the attribute to be added to each output tile that records the total number of tiles produced vertically by the tiling operation on the input raster.
How to Set Parameter Values
Text Editor
Arithmetic Editor
Dialog Options - Tables
- Add a row
- Remove a row
- Move current row up one
- Move current row down one
- Move current row to top
- Move current row to bottom
- Cut a row - delete and copy to clipboard
- Copy a row to the clipboard
- Paste a row from the clipboard
Cut, copy, and paste may be used within a transformer, or between transformers.
Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output.
Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies |
None |
Aliases |
History |
Search for all results about the RasterTiler on the FME Community.
