PointCloudSimplifier
Reduces the number of points in a point cloud by selectively keeping points based on the shape of the point cloud. The simplified and removed points are output as two discrete point clouds.
Jump to Configuration
- Reducing the data volume of a point cloud feature to meet processing or storage requirements, when honoring the overall shape of the original dataset is desirable.
The PointCloudSimplifier receives point cloud features and outputs them with fewer points than the original. The points to keep are identified by an algorithm that determines the overall shape of the point cloud, and then selectively discards points.
Areas with high rates of change (such as steep slopes) will have more points kept, and areas with low rates of change (generally flat areas) will be thinned more aggressively. This is based on the Medial Axis Transform (MAT) of the original, a representation like a skeleton of the entire point cloud feature. Individual points are considered against the MAT and evaluated for inclusion or exclusion.
The manner of generation of the MAT, method of sampling, and desired level of simplification can be optionally adjusted through parameters.
Both the simplified point cloud and a new point cloud feature containing all removed points are output.
Note: Medial Axis Transform (MAT) Simplification. This method estimates normals for each point and uses a ball-shrinking algorithm to approximate the MAT. Then it samples the point cloud based on each point’s Local Feature Size (LFS), defined by the shortest distance from the point to the medial axis. Points in areas of high curvature (low LFS) are sampled at a higher density than redundant low curvature (high LFS) points.
Example: Simplifying a point cloud
In this example, we will reduce the number of points in a point cloud, while honoring the original shape of it.
Note that the source dataset has over 6 million points in it. Viewed here in the FME Data Inspector at an oblique angle, we can see that it contains a number of tall structures in a fairly flat area.
The point cloud feature is routed into a PointCloudSimplifier.
In the parameters dialog, the default settings are kept.
The output point cloud has been reduced to just over 1.6 million points. Note that areas with rapid elevation change - the structures - remain largely intact, whereas large flat areas with little change in elevation have been thinned much more aggressively.
Compare the point cloud before and after simplification:
- This transformer is very processing intensive. The PointCloudThinner also reduces the number of points in a point cloud, using either regular sampling intervals or first/last x points. It is much faster than the PointCloudSimplifier, but does not consider the shape of the feature.
Point Cloud Transformers
PointCloudCoercer
Converts point clouds to point or multipoint geometries, optionally retaining attribute and component values.
PointCloudCombiner
Combines features into a single point cloud. Point cloud and non-point cloud geometries are supported.
PointCloudComponentAdder
Adds new components with constant values to a point cloud.
PointCloudComponentCopier
Copies selected component values onto either a new or existing component
PointCloudComponentKeeper
Keeps only specified point cloud components, discarding all others.
PointCloudComponentRemover
Removes specified components from a point cloud.
PointCloudComponentRenamer
Renames an existing component.
PointCloudComponentTypeCoercer
Alters the data type of point cloud components, and converts component values if required.
PointCloudConsumer
Reads point cloud features for testing purposes, including any accumulated point cloud operations. No additional operations are performed, and nothing is done with the features.
PointCloudCreator
Creates a point cloud of specified size and density, with default component values.
PointCloudExpressionEvaluator
Evaluates expressions on each point in a point cloud feature, including algebraic operations and conditional statements, and sets individual point cloud component values.
PointCloudExtractor
Serializes the geometry of a point cloud feature into a Blob attribute, encoding the contents according to a choice of common binary point cloud formats.
PointCloudFilter
Separates point clouds into multiple features, based on evaluating expressions including component values, and creates a separate output port for each expression defined.
PointCloudMerger
Merges point clouds by joining points where selected component values match (join key), including x, y, z, and other components. Component values are transferred between point clouds and output is filtered based on matching success and duplication.
PointCloudOnRasterComponentSetter
Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location.
PointCloudPropertyExtractor
Extracts the geometry properties of a point cloud feature and exposes them as attributes, optionally checking for their existence, retrieving component properties, and finding minimum and maximum values. Extents may also be recalculated and updated.
PointCloudReplacer
Decodes a binary attribute containing encoded point clouds stored as Blobs, replacing the feature’s geometry with the decoded point cloud.
PointCloudSorter
Sorts the points within a point cloud by one or more component values.
PointCloudSplitter
Separates point clouds into multiple features based on component values, color, or first/last return.
PointCloudStatisticsCalculator
Calculates statistics on point cloud components and adds the results as attributes.
PointCloudSurfaceBuilder
Takes an input point cloud and reconstructs it into an output mesh.
PointCloudThinner
Reduces the number of points in (thins) a point cloud by keeping points at a fixed interval, a maximum number of points, or a set quantity of first or last points. Remaining points are discarded.
PointCloudTransformationApplier
Applies a point cloud’s scale, offset, or transformation matrix to it, recalculating component values and removing the transformation values.
Input
Simplified
Point cloud features with a simplified subset of the original points.
Removed
Point cloud features containing all points not included in the simplified point cloud.
<Rejected>
INVALID_PARAMETER_<KEYWORD>
NO_RESULT
Simplification Algorithm
Algorithm
Medial Axis Transform: Perform simplification based on the Medial Axis Transform (MAT). This method estimates normals for each point and uses a ball-shrinking algorithm to approximate the MAT. Then it samples the point cloud based on each point’s Local Feature Size (LFS), defined by the shortest distance from the point to the medial axis. Points in areas of high curvature (low LFS) are sampled at a higher density than redundant low curvature (high LFS) points.
Medial Axis Transform Parameters
Filter Ratio
Specifies the desired level of simplification, relates LFS values to sampling density. Higher values will result in lower overall density.
Typical values range from 0.01 to 0.8.
Minimum Sampling Density
Specifies the minimum sampling density for grid cells (in points per square unit).
A value of 0 means that the sampling density is not bounded from below. This can be useful to maintain a minimum level of detail in nearly flat regions which would otherwise be removed entirely because of plane detection.
Maximum Sampling Density
Specifies the maximum sampling density for grid cells (in points per square unit).
A value of 0 means that sampling density is not bounded from above.
LFS Based Simplification
Linear: Use the unmodified LFS values for each point during simplification.
Quadratic (LFS^2): Use the square of the LFS value for each point during simplification. This will increase the effect that curvature has on point sampling.
Tuning and Noise Reduction |
Grid Cell Size
Specifies the cell size for grid-based LFS simplification. During simplification, the point cloud is divided into a uniform grid of this size. The sampling density is calculated for each cell based on the average LFS values of its contained points. This should be as small as possible, but large enough to have an average of 5-10 points per cell.
Auto: Let FME estimate a reasonable cell size based on the bounding box and number of points in the input point cloud.
Initial Ball Radius
Specifies the initial radius used by the ball-shrinking algorithm. Larger values will allow for the detection of larger shapes when approximating the MAT.
Auto: Let FME estimate a reasonable initial radius based on the bounding box and number of points in the input point cloud.
Normal Estimation Neighbors
Specifies the number of nearby points to consider when estimating point normals. Use higher values with denser inputs to produce more consistent normals.
Typical values range from 5 to 20.
Ball Preservation Threshold
Specifies the minimum angle (in degrees) between the defining points for a medial ball during a ball-shrinking iteration. Iteration stops when the angle would fall below this threshold.
A value of 0 means that no ball preservation takes place.
Typical values range from 0 to 30.
Plane Detection Threshold |
Specifies the minimum angle (in degrees) between the defining points for the initial medial ball. If the angle on the first iteration is below this threshold then no medial ball is assigned.
A value of 0 means that no plane detection takes place.
Typical values range from 0 to 40.
Advanced
Bisector Neighbors
Specifies the number of nearby points to check against the Bisector Threshold. Higher values will result in fewer noisy MAT points but will also limit the ability to detect small features.
Typical values range from 1 to 5.
Bisector Threshold
The Bisector Threshold is used to clean the MAT points before LFS computation. Lower values mean more aggressive cleaning which means more robustness to noise in the MAT, but fewer features will be detected.
Typical values range from 0.1 to 10.
LFS Computation |
Use Interior MAT Only: Only consider the interior MAT when computing LFS values.
Use Interior and Exterior MAT: Consider both the interior and exterior MAT when computing LFS values.
How to Set Parameter Values
Text Editor
Arithmetic Editor
Dialog Options - Tables
- Add a row
- Remove a row
- Move current row up one
- Move current row down one
- Move current row to top
- Move current row to bottom
- Cut a row - delete and copy to clipboard
- Copy a row to the clipboard
- Paste a row from the clipboard
Cut, copy, and paste may be used within a transformer, or between transformers.
Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output.
Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies |
None |
Aliases |
History |
Search for all results about the PointCloudSimplifier on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
