LocalCoordinateSystemSetter
Assigns a specified local coordinate system to features, without modifying geometry or coordinates.
- Adding missing local coordinate systems
- Adding local coordinate systems when the features’ original format does not support them.
- Fixing incorrect local coordinate systems
The LocalCoordinateSystemSetter receives any feature and assigns a specified local coordinate system to it. No geometry is modified, and data is not reprojected.
The local coordinate system may be either Equidistant (AZMED) or Equal Area (AZMEA), and a choice of ground units is provided.
The local coordinate system is mapped to a true coordinate system by selecting that coordinate system and entering the X and Y coordinates that match 0,0 in the local coordinate system
Note that Z coordinates are not considered, and so areas or distances are best preserved for geometry at an ellipsoid height of zero (0) meters.
If a feature already has a coordinate system assigned (local or otherwise), it will be overwritten.
In this example, we have an OBJ file containing a 3D model of a public library. Note that the Coordinate System is Unknown, and that the extents would be appropriate coordinates for a local coordinate system.
We know what the local coordinate system should be, and so need to assign it without modifying the feature geometry.
The feature is routed into a LocalCoordinateSystemSetter.
In the parameters dialog, we select a Projection Type of Equidistant (AZMED) and Projection Units of Meters.
Origin coordinates are entered as Lat/Long NAD83.
The output feature now knows its local coordinate system. Note that the extents are unchanged, as the feature’s coordinates have not been modified. .
- If ground units need adjustment to match the coordinate system, consider using a Scaler prior to this transformer.
Coordinate System Support
Library |
FME (default) or Esri |
Library (External Links) |
Sweden |
Sweden |
Switzerland |
Features with a new coordinate system assigned as specified in parameters.
Projection Type |
Select a Projection Type based on whether preservation of distances or areas will be more important during subsequent reprojections. Choices include:
Projection Units |
Choose the units of the features that will be entering the transformer. Choices include:
Origin Coordinate System |
Specify the coordinate system of the origin point. The created local coordinate system will be based on the datum of this coordinate system. |
Origin X |
Specify the X coordinate of the point that corresponds to 0,0. |
Origin Y |
Specify the Y coordinate of the point that corresponds to 0,0. Origin points within 0.5 degree of the North or South Pole will cause an error. |
Dialog Options - Tables
Dependencies | None |
Aliases | |
History |
Search for all results about the LocalCoordinateSystemSetter on the FME Community.
