Calculates a decimal degree value from separate degrees, minutes, and seconds (DMS) values, provided as attributes.
                                                    Calculating the decimal degree equivalent of latitude and longitude DMS (degrees, minutes, seconds) values.
The DecimalDegreesCalculator receives any feature with attributes containing valid degrees, minutes, and seconds values, and converts those to decimal degrees. The result is added to the output feature as an attribute.
If an invalid (for example, non-numeric) value is received, the translation will fail.
 Example: Converting DMS to decimal degrees
                                                In this example, we have a dataset of world cities, with latitude and longitude coordinates stored as attributes, in degrees, minutes, and seconds.
We want to convert these into decimal degree values, and will start with latitude.
The features are routed into a DecimalDegreesCalculator.
In the parameters dialog, Degrees, Minutes, and Seconds Attribute(s) are set to the corresponding latitude attributes - lat_degrees, lat_minutes, and lat_seconds. The default output attribute name is prefixed with lat_.
The output features now have a lat_decimal_degrees attribute, containing the calculated decimal degree value.
                                                    If degrees, minutes, and seconds are concatenated into a single string, they can be extracted with a StringSearcher or AttributeManager with string functions.
 Input
Input
                                                Features with degrees, minutes, and seconds values stored as individual attributes.
 Output
Output
                                                Features with decimal degree values added as specified in parameters.
 General
General
                                                | Degrees Attribute | Specify the source attribute containing the degrees value. |
| Minutes Attribute | Specify the source attribute containing the minutes value. |
| Seconds Attribute | Specify the source attribute containing the seconds value. |
| Destination Degrees Attribute | Name the attribute to contain the resulting decimal degrees values. |
Using a set of menu options, transformer parameters can be assigned by referencing other elements in the workspace. More advanced functions, such as an advanced editor and an arithmetic editor, are also available in some transformers. To access a menu of these options, click  beside the applicable parameter. For more information, see Transformer Parameter Menu Options.
 How to Set Parameter Values
 Content Types
Content Types
| Special Characters | A set of control characters is available in the Text Editor. |
Dialog Options - Tables
                                                | Row Reordering
        | Enabled once you have clicked on a row item. Choices include:
| Cut, Copy, and Paste
| Filter
        | Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output. |
| Import
        | Import populates the table with a set of new attributes read from a dataset. Specific application varies between transformers. |
| Reset/Refresh
        | Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers. |
| Processing Behavior | |
| Feature Holding | No |
Search for all results about the DecimalDegreesCalculator on the FME Community.
