CoordinateRounder
Rounds off the coordinates of the feature to the specified number of decimal places.
Generalizing features
Altering coordinates to match a schema or dataset
Rounding coordinates where precision exceeds accuracy
The CoordinateRounder receives vector features and rounds their x, y, and/or z coordinates to a specified precision.
X, Y, and Z Precision parameters are specified as integers, and may be entered directly or set to an expression, user parameter, attribute, or conditional value. Positive numbers represent the number of decimal places to round to, and negative numbers produce rounding to multiples of ten (10). A precision of zero (0) produces integers - coordinates with no decimal places.
If any of the Precision parameters are left blank, those coordinates will pass through unaltered.
For arcs, only the start and end points are rounded, as these are the only coordinates which lie on the path of the arc. The center point is not rounded, nor are any other of the arc's parameters.
Point clouds and rasters are passed through unaltered.
Rounding Errors and Floating-Point Processing
The CoordinateRounder may not always behave as expected, due to known limitations in floating-point computing.
Representing decimal (base 10) numbers in binary (base 2) can result in infinitely repeating values - much like 1 divided by 3 (that is, ⅓) results in 0.3333 (repeating to infinity) in the decimal number system.
For example, 1 divided by 5 (that is, ⅕), which produces 0.2 in the decimal system, recurs infinitely when represented as a binary value:
0.0111 1111 1001 0011 0011 0011 0011 0011... (0011 repeating)
When this value is converted back to a decimal, it produces 0.200000000000000011102230246252.
As a result, rounding can sometimes be unpredictable, rounding in an unexpected direction.
Some numbers like 1.1 cannot be stored precisely in binary and so end up as 1.1000000000000001, regardless of rounding. Rounding to 3 decimal places also results in 1.1000000000000001. Similarly, a value of 3.3333 is stored as 3.3332999999999999, and when rounded to 2 decimal places ends up as 3.3300000000000002.
Note that the same behavior may not be seen when values are handled as strings, as in the AttributeRounder, but they will be affected whenever the value is used as floating point.
Coordinates in FME are typically logged with full floating-point precision, including any floating-point processing precision error. Note that many formats have a way of controlling decimal precision based on data types or precision as set on the writer.
In this example, we have a dataset of park polygons. Note that the coordinate system is UTM83-10, and so the ground units are meters.
Examining the coordinates of individual nodes in one area feature, we see numbers with nine or more decimal places. Considering we are measuring in meters, that precision far exceeds our possible accuracy. We will round the coordinates.
The features are routed into a CoordinateRounder.
In the parameters dialog, both the X and Y Precision are set to 2, which will round to two decimal places, representing centimeters in this coordinate system.
Z Precision is left blank. The dataset is 2D, and does not have Z coordinates.
The output features have coordinates rounded to two decimal places.
Rounding can produce duplicate nodes. The GeometryValidator may be used to remove them.
To perform rounding on raster cells, use the RasterCellValueRounder.
To perform rounding on point clouds, use the PointCloudExpressionEvaluator.
To perform rounding on coordinates stored as attributes, use the AttributeRounder.
Vector features with coordinates to be rounded.
Features with coordinates rounded as specified in parameters. Features with unsupported geometry (raster, point cloud, no geometry) are passed through unaltered.
X Precision |
Enter a precision for the x coordinate. |
Y Precision |
Enter a precision for the y coordinate. |
Z Precision |
Enter a precision for the z coordinate. |
Dialog Options - Tables
Dependencies | None |
Aliases | |
History |
Search for all results about the CoordinateRounder on the FME Community.
