AttributeFileWriter
Writes the contents of an attribute to a text or binary file.
- Writing files mid-workspace that contain the value of an attribute
- Replacing a writer where the desired content is stored as an attribute
- Writing images that have been stored as blob attributes
- Writing coordinate system information to a file
- Writing text lists of attribute values
The AttributeFileWriter receives any type of feature and writes the contents (value) of a specified attribute to an external file.
A Target Filename and encoding type must be specified. File names may be provided explicitly or by attribute value, expression, user parameter, or conditional value. If a target file already exists, it may be overwritten or appended to.
The attribute value and target file may be text or binary. A variety of encoding choices are available for text files. Binary files should be designated as Binary (fme-binary), as the transformer writes it as-is and will simply preserve the attribute contents as a Blob.
- When writing any binary file types, ensure that Target File Encoding is set to Binary (fme-binary).
- Full path names can be created from existing attribute values by using the Text Editor to create an expression.
- The most common text encodings are Windows Latin-1 (windows-1252) and Unicode 8-bit (utf-8).
- If you are unsure of the encoding used by the attribute, the Feature Information window in the FME Data Inspector will often help (see image in previous example)
Dialog Options - Tables
Dependencies | None |
Aliases | |
History |
Search for all results about the AttributeFileWriter on the FME Community.
