Snowflake Non-Spatial Writer: Feature Type Parameters
To access feature type parameters, click the gear icon on a feature type in the workspace. This opens the Feature Type Parameter Editor.
Tip: To always display the editor in Workbench, you can select View > Windows > Parameter Editor.
General
All feature types share similar General parameters, which may include Feature Type Name, Reader or Writer information, and Geometry.
In most Writer Feature Type parameter dialogs, you can also control Dynamic Schema Definitions. Some database formats accept Table or Index Qualifier prefixes on the output table feature type.
These parameters apply only to a selected feature type, not to the entire writer.
Note: If a feature type parameter listed here conflicts with a writer-level parameter, then the writer parameter will be ignored and this feature type parameter will be used.
Table Settings: General
Use Bulk Loading
This parameter is only available when Feature Operation is Insert. If enabled, the writer performs INSERT operations using bulk insert, which offers significant performance improvements.
Note: Currently there is a known issue where this operation is unable to write to tables with names containing special characters (for example, spaces, punctuation, symbols).
