LDAP/Active Directory: User Attributes
Readers: For information on the parameters in this dialog that are common to all readers, see:
Writers: For information on the parameters in this dialog that are common to all writers, see:
User attributes for this format are defined below.
Name The name of the field to be read.
Type
This format supports the following field types.
integer
This type is used to represent 64-bit signed integers.
directorystring
This type is used to represent character data.
distinguishedname
This type is used to represent a location in the LDAP tree hierarchy.
