Reverting Applications
                                                If the Status of an application is Extended, the Action column will contain a Revert button.
                                                Note: Ensure that the extended application is closed.
                                                Press the button to revert the application to a Not Extended state.
                                                The log pane will display status information.
                                                Extending Applications
                                                Troubleshooting
