Upgrading to a Second Machine, Using a Different Host Name
Note: If the FME Server you are upgrading from was configured for HTTPS, you must reconfigure HTTPS after the upgrade is complete.
- Provide a new machine for the upgrade.
- Backup the FME Server configuration from the old machine.
- Install FME Server on the new machine. On the FME Server Hostname dialog, specify the new hostname.
- Restore the backed-up FME Server configuration to the new machine.
- Test that your configuration has been migrated successfully.
- Uninstall FME Server from the old machine (or recycle the machine).
Note: If your FME Server installation includes an FME Server Database that is configured on your own database server, you must perform the step to Configure the FME Server Database on a Separate Database Server as part of installation. You cannot reuse the FME Server Database from a previous installation because the table schemas may differ from the upgraded version.
Note: Hardcoded paths to the previous host name in workspaces, transformers and HTTP push subscriptions must be manually updated.
