StatisticsCalculator
Calculates statistics based on a designated attribute or set of attributes of the incoming features and adds the results as attributes.
- Inspecting and analyzing features
- Calculating statistics for use in further operations
The StatisticsCalculator receives features and calculates selected statistics on them per attribute. Statistics can be calculated on specific groups of input features as specified by the Group By attribute option. The results are output on each feature out of the Complete port. A summary of the results is output out of the Summary port.
Available statistics include:
- Minimum
- Maximum
- Mean
- Sum
- Range
- Standard Deviation (Sample or Population)
- Median
- Mode
- Total Count
- Numeric Count
- Histogram
The following statistics may also be calculated cumulatively on attributes using advanced settings: min, max, range, mean, stdev, sum, total count, numeric count. When calculating cumulative statistics, the current results thus far are output on each feature out of the Cumulative port.
Statistics are stored as attributes, named <attribute>.<statisticname>, where <statisticname> will be one of the following: min, max, range, mean, stdev, stdev_p, sum, median, mode, total_count, numeric_count, histogram.
Histogram statistics are stored as list attributes that pair the attribute value and count for each unique value of the attribute and are named <attribute>.histogram{#}.value and <attribute>.histogram{#}.count where # is a zero-based index of the unique attribute values.
All features enter the transformer through the Input port.
A single new feature will be output containing the statistics attributes for each group. If features are not grouped, the latter will emit a single feature containing the statistics for the whole set of input features.
No summary features will be generated if no input features are provided.
All Input features will all be passed through this output port with all the statistics attributes for their group added onto them. Note that this will require all Input features to be stored until the end of translation, which can greatly increase the amount of memory and/or temporary disk storage usage.
All Input features will all be passed through this output port with all the statistics attributes to date for their group added onto them. The features pass through this port immediately, each having the statistics computed for the set of features from the first feature in the group through to the current feature. (Note that this differs from the “final” statistics output in the Complete group.)
| Group By | If Group By attributes are chosen, statistics will be calculated independently within each group of features. This can be used to create a pivot-table-like analysis of values in a data stream. |
| Group By Mode |
| Calculation Method |
Use this setting to specify a method for evaluating values when calculating statistics. This choice will be applied to all data when it enters the transformer, determining whether values should be treated numerically or lexically. |
| Attribute | Select which attributes to include, one per line. | ||||||||||||||||||||||||
| Statistics |
The following statistics may be calculated:
Select All |
This toggle works in conjunction with currently selected rows in the Statistics to Calculate table and will enable or disable all statistic type choices. |
Add Attributes... |
Provides a pick list of all currently available attributes to perform multiple attribute addition to the Statistics to Calculate table. |
Enable this section to calculate cumulative statistics and make the Cumulative output port visible. This table specifies which cumulative statistics to calculate for each attribute.
Input Data Handling
Invalid, <null>, and <missing> data are considered invalid and will be skipped when calculating statistics other than total count. If no valid values are processed when calculating a statistic the result will be <missing>. Trying to calculate standard deviation on only one value will also result in <missing>. Total count and numeric count will never be <missing>. NaN values are explicitly ignored when calculating Min, Max, Range, and Numeric Count.
For example, a calculated sum on all <missing> values will be <missing> rather than a potentially misleading and less informative 0. However, if only some values are <missing> or invalid the resulting sum will be the same as if those values were 0.
Backwards Compatibility
The StatisticsCalculator transformer has default suffixes and always prepends. Upgraded transformers will retain prepend settings when output attribute names were not prepended before upgrade as well as suffix names to maintain backwards compatibility and avoid disrupting existing workspaces.
Example
The StatisticsCalculator transformer can generate statistics for groups of features rather than all features. This effectively adds the ability to create pivot tables in FME similar to pivot tables in Excel.
Note: The AttributePivoter transformer provides a simpler approach to generate some forms of pivot tables.
Source Table and Excel Pivot Table
Fictitious data generated in Excel was exported to a CSV file for use in Workbench. A simple pivot table was also created in Excel to show what we want to produce from FME; basically we want to summarize observed values based on region and potential.
FME Pivot Table
The workspace shown below uses the StatisticsCalculator transformer to create statistics for the observed attribute by first grouping features by region and potential. Then the new statistics features are sorted by region and potential, and output to a CSV file. The resulting CSV file has all of the same attributes/fields as the Excel pivot table.
The table written by FME and viewed in Excel resembles the Excel pivot table:
You can also use the ChartGenerator transformer to chart the data.
Dialog Options - Tables
