RasterObjectDetectorSampleGenerator
Aids in generation and preparation of positive and negative samples to be used by the RasterObjectDetectionModelTrainer.
RasterObjectDetectorSampleGenerator requires a single positive image of the object you are attempting to detect and will artificially generate a large number of samples by morphing the image source. We do not recommend this method for most users, since many times, a smaller number (for example, 100) of carefully hand-picked positive samples can result in a better detection model than a larger number (for example, 1000) of artificially generated. Therefore, to get better results we recommend RasterObjectDetectorSamplePreparer.
Input
The transformer accepts any feature but all contents (except parameters) will be ignored and preserved with the output feature.
Output
The Output port returns the original feature and the following attributes:
- _out_bg_desc_fname: Path to the background description file
- _out_num_negative_samples: Number of negative samples in the background description file
- _out_vec_fname: Path to the .vec file which will contain the positive samples
- _out_num_positive_samples: Number of positive samples in the .vec file
<Rejected>
This port returns a feature with all its original contents and an fme_rejection_message containing the error message if any occur.
Negative Samples
Training a detection model requires a set of negative or background images that do not contain the object you are trying to detect. Depending on the application, you may get away with using random images. However, if your object(s) have a very specific background, you may want to take the positive samples (if you have any) and crop out the object to get some samples that do not contain your object.
Source Directory
Directory containing negative sample images. For best operation, make sure the names do not contain spaces or special characters.
Operation Mode
- Use Existing: If the background description file does not exist it will be created. If it does exist, it will be used for translation.
- Overwrite: The file will be re-generated every time.
Positive Samples
Source Image
Single image source that will be morphed to generate samples. The source should only contain your image. Image will be overlayed on top of the provided negative samples, twisted, rotated and have its colors tweaked. Those parameters can be tweaked in the Advanced settings.
Width and Height
Width and Height of the detection window of the resulting detection model. Determines the minimum size of the object that the model will be able to detect.
Output
Advanced
Starting Transparency Value
Background color that denotes transparent color. Since there might be compression artifacts, the amount of color tolerance can be specified by the Transparency Threshold parameter.
All pixels within the following range: from (Starting Transparency Value - Transparency Threshold) to (Starting Transparency Value + Transparency Threshold) are interpreted as transparent.
Invert Colors
If the parameter is set to Yes, colors will be inverted.
Invert Randomly
If the parameter is set to Yes, colors will be inverted randomly.
Maximum Sample Scale
When specified, the source image will not be scaled beyond the number specified when it is being placed in the background image. If not specified, the background image size determines the maximum scale.
Random Number Generator Seed
RNG Seed can be used to reproduce the same results of samples generation. If the seed is left unspecified, the seed is determined randomly.
How to Set Parameter Values
Text Editor
Arithmetic Editor
Dialog Options - Tables
- Add a row
- Remove a row
- Move current row up one
- Move current row down one
- Move current row to top
- Move current row to bottom
- Cut a row - delete and copy to clipboard
- Copy a row to the clipboard
- Paste a row from the clipboard
Cut, copy, and paste may be used within a transformer, or between transformers.
Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output.
Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.
