Offsetter
Adds offsets to the feature's coordinates.
After you connect the transformer, you can enter parameter values as a number or pick the value of a feature attribute by picking Set to Attribute Value from the Parameter menu.
The feature will be shifted by the amounts specified.
General
Cartesian Coordinate Parameters
Polar Coordinate Parameters
Spherical Coordinate Parameters
Point Cloud
This transformer works with both raster and vector data.
This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
This example shows an image offset using the x and y parameters:
Dialog Options - Tables
Keywords: raster vector coordinates offset pointcloud
