LatLongToMGRSConverter
Calculates a Military Grid Reference System (MGRS) code based on latitude and longitude values.
Determining which standard MGRS boundary contains a given point.
The LatLongToMGRSConverter accepts any feature. The user specifies attributes, expressions, or user parameters containing latitude and longitude coordinates, along with the Ellipsoid and desired Lettering Type.
The standard MGRS code is generated to the specified Precision, and stored as an attribute.
Precision is an integer from 0 to 5 (inclusive). A precision of 5 locates a point within a 1-meter square and precision of 0 locates a point within 100-km square.
For more information on the MGRS, see Military Grid Reference System.
This transformer does not operate on geometry. To extract coordinates from geometry for conversion, consider using the CoordinateExtractor or @XValue() and @YValue() functions.
Dialog Options - Tables
Dependencies | None |
Aliases | |
History |
Search for all results about the LatLongToMGRSConverter on the FME Community.
