HullAccumulator
Creates convex or concave hulls for groups of features. One hull feature is output for each unique combination of values of the attributes specified in the Group By parameter.
Group Processing
Hull Parameters
Output Dimension
Example
  • Point Clouds: the HullAccumulator does not consider individual points within a point cloud feature, and will produce the equivalent to a bounding box. To generate a hull from point cloud points, use a PointCloudCoercer prior to the HullAccumulator, setting the Output Geometry parameter to either Single Multipoint or Individual Points.
Dialog Options - Tables
Transformer History
This transformer was previously named ConvexHullAccumulator.
Keywords: ConvexHullAccumulator
