DEMDistanceCalculator
Calculates the distance between a number of input vector lines and the elevation values of a reference DEM raster, and outputs a new DEM raster per input line.
The data contained in the resulting DEM consists of the 3D distance between the line being considered and the corresponding point on the reference DEM.
Group Processing
This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
Dialog Options - Tables
Keywords: raster band palette vector distance DEM
