DecimalDegreesCalculator
Calculates a decimal degree value from separate degrees, minutes, and seconds (DMS) values, stored in attributes.
General
If the degrees/minutes/seconds are together in a single attribute, they can be parsed apart using the StringSearcher transformer.
For instance, if the attribute has the format:
  -DDDMMSS.SSĀ°
the following regular expression could be used in the StringSearcher to parse it into a list attribute with three elements:
  ^(-?[0-9]+)([0-9][0-9])([0-9][0-9][.][0-9]*)
The three elements could then be exposed and used as input to this transformer.
Dialog Options - Tables
Keywords: latitude longitude degrees minutes seconds
