Creator
Creates features using the parameters supplied, and sends them into the workspace for processing.
The Creator's interface allows you to select the desired type of geometry, then enter the coordinates and/or parameters that will create the desired object.
This transformer does not have any input ports.
General
Dialog Options - Tables
Keywords: 2DCreator 3DCreator Creator3D
