AutodeskBIM360DocsConnector
Accesses BIM 360 Docs to upload, download, or delete files and folders or list file/folder information.
Jump to Configuration
  • Manage files on BIM 360 Docs by uploading, downloading, and deleting files and folders.
  • Transfer a file's contents into or out of an attribute in FME.
  • Retrieve file and folder names, paths, and other information from BIM 360 Docs to use elsewhere in a workspace.
The AutodeskBIM360DocsConnector uses your BIM 360 Docs account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the file storage service.
Depending on your choice of actions, it will upload or download files, folders, and attributes; list information from the service; or delete items from the service. On Upload and List actions, links and file/folder information are added to the output features as attributes.
Authentication
The AutodeskBIM360DocsConnector uses an oauth web service defined FME web connection. It is recommended to create a new web connection using the Autodesk BIM 360 Docs (safe.autodesk-bim360docs) web service. It is also recommended to replace the included FME Forge app client with your own Forge application by updating the client id and secret in Autodesk BIM 360 Docs (safe.autodesk-bim360docs). At minimum, the Forge app must have access to the BIM 360 and Data Management APIs.
It is also required to add the chosen Forge App as a custom integration on the BIM 360 Hub page. A hub admin can do this by logging in and going to Account Admin > Settings > Custom Integrations > Add Custom Integration and entering the client ID of the connected Forge App. For the included FME Forge app, this is visible by examining the Autodesk BIM 360 Docs (safe.autodesk-bim360docs) web connection settings.
  • This transformer cannot be used to directly move or copy files between different BIM 360 Docs locations. However, multiple AutodeskBIM360DocsConnectors can be used to accomplish this, by downloading files/folders and re-uploading them to a new location.
The remaining parameters available depend on the value of the Action parameter. Parameters for each Action are detailed below.
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies BIM 360 Account, recommended to have a Forge App with access to the BIM 360 API and the Data Management API
Aliases
History Released FME 2020.2
Search for all results about the AutodeskBIM360DocsConnector on the FME Community.
