AttributeExposer
- Exposing attributes that a workspace is not aware of, such as those created by a SchemaMapper
- Exposing normally unexposed fme_ and format-specific attributes for use in the workspace
- Exposing attributes in a dynamic translation where source attributes may vary
The AttributeExposer makes unexposed attributes visible in Workbench so they can be used elsewhere in the workspace. This transformer is useful if you know features have an attribute, but that attribute is not currently showing as available in your workspace. For example:
- FME Attributes (fme_) and more obscure format-specific attributes that are not automatically shown in Workbench.
- Transformers, such as the SchemaMapper, that dynamically add attributes onto features which Workbench is not aware of.
You may enter the attribute names manually, or import attributes from any supported source dataset. Known attributes (including fme_ and format-specific attributes that are not currently exposed) can be selected from the drop-down menu.
This transformer only exposes the attribute in Workbench - it does not ensure that valid attribute names are being exposed. The input features are not modified in any way.
Once the attributes are exposed, they can be accessed elsewhere in the workspace.
Cached Values and Data-Aware Attribute Names
If Feature Caching is enabled, valid attribute names from upstream features are shown for attribute selection.
- Expose attributes fme_basename and fme_dataset in the reader feature type or the FeatureReader transformer. These attributes are not read unless they are exposed in this manner.
Dialog Options - Tables
Dependencies | None |
Aliases | |
History |
Search for all results about the AttributeExposer on the FME Community.
