BC MoF Electronic Submission Framework – (XSD-Driven) Reader Parameters
Application Schema
ESF Submission
The parameter specifies the ESF submission format. By default, the reader will Guess from Dataset to determine the format. Valid values are:
- Guess from Dataset
- FSP (Forest Stewardship Plan)
- FTA (Forest Tenures)
- RESULTS (silviculture)
- RRS (Resource Road Systems)
- Other Application Schema
Application Schema
This parameter is only applicable when ESF Submission is set to Other Application Schema. It allows the reader to be used for other types of submissions that are not explicitly supported.
Note that most ESF submission schemas do not themselves import the esf-submission.xsd. This schema file declares the root element, <esf:ESFSubmission>, that is used by all the ESF submission documents. Therefore, the esf-submission.xsd should also be specified when specifying the other submission type xsd. For example:
c:\schemas\ftc\mof-ftc.xsd c:\schemas\ftc\esf-submission.xsd
Validate Dataset
If checked, validates schemas against the website schema. Errors are reported if the schema does not match.
Ignore xsi:schemaLocation in Dataset
This parameter can be used to tell the reader to ignore the schema files that are specified in the xsi:schemaLocation attribute of the root element in the dataset. This is particularly useful if the file locations specified in xsi:schemaLocation are not valid file paths.
Schema Attributes
- In a non-dynamic scenario, this parameter allows you to expose additional attributes on multiple feature types. Click the browse button to view the available format attributes (which are different for each format) for the reader.
Using the minimum and maximum x and y parameters, define a bounding box that will be used to filter the input features. Only features that intersect with the bounding box are returned. (Note that this is the bounding box intersection only, and not a full geometry intersection that would be returned by a transformer like the SpatialFilter.)
If all four coordinates of the search envelope are specified as 0, the search envelope will be disabled.
Clip to Search Envelope
When selected, this parameter removes any portions of imported features being read that are outside the Search Envelope.
The example below illustrates the results of the Search Envelope when Clip to Search Envelope is not selected (set to No) and when it is selected (set to Yes).
- No: Any features that cross the search envelope boundary will be read, including the portion that lies outside of the boundary.
- Yes: Any features that cross the search envelope boundary will be clipped at the boundary, and only the portion that lies inside the boundary will be read. The underlying function for the Clip to Search Envelope function is an intersection; however, when Clip to Search Envelope is selected, a clipping operation is also performed in addition to the intersection.
Use Network Authentication
This parameter is always visible in some formats, and visible in other formats only when the dataset is a URL.
Specify the authentication method to use when accessing a password-protected server.
- Basic (default) – Basic access authentication is designed to allow a client to provide credentials to a server on the assumption that the connection between them is trusted and secure. Note that any credentials passed from client to server can be easily intercepted through an insecure connection.
- Digest – Digest authentication is one of the agreed-upon methods a web server can use to negotiate credentials, such as username or password, with a user's web browser.
- NTLM – A challenge-response protocol that is used to provide compatibility with versions of Windows earlier than the Windows 2000 operating systems.
- Web Connection – Web connections provide a convenient and secure way to store and reuse previously established connection parameters. See Web Connection below.
- Single Sign-on – FME will use the credentials of the current user to authenticate the HTTP request. This authentication method currently works only on the Windows operating system.
Note: To access datasets using a proxy server, use the Network tools in FME Options. From the Workbench menu, select Tools > FME Options > Network. For more information, see "Network Proxy" in the FME Workbench Help.
