StringSearcher
Performs a regular expression match on the specified expression. If the expression matches the pattern, the feature is output via the Matched port, and the portion of the original search string that matched the regular expression is stored in the attribute specified in the Matched Result Attribute (and optionally matching pieces of the expression are stored in the attribute list specified in the All Matches List Name and Subexpression Matches List Name parameters, along with the starting indices of each piece). Otherwise, it is output via the NotMatched port.
General
The input text to be searched.
To use this transformer to parse out portions of a string, regular expressions are used. The portion of the input text that matched the regular expression is stored as an entry in the All Matches List Name list. The elements of this list can then be exposed to Workbench by right clicking on it and indicating the number of elements to expose for later use. See below for some examples.
Advanced Regular Expressions (AREs) are supported. For a complete description of AREs, see Syntax of Perl-Compatible Regular Expressions at http://perldoc.perl.org/perlre.html#Regular-Expressions.
In brief, an ARE is one or more branches, separated by |, matching anything that matches any of the branches.
A brief summary of the special characters and their meanings is:
| | separates "branches" (or choices) |
* | a sequence of 0 or more matches of what precedes it |
+ | a sequence of 1 or more matches of what precedes it |
? | a sequence of 0 or 1 matches of what precedes it |
. | matches any single character |
^ | matches the start of the value |
$ | matches the end of the value |
[ ] | enclose a set of character choices |
( ) | enclose a "subexpression" -- whatever matches each subexpression is placed into the “Subexpression Matches List Name”{} list attribute |
a | any character can be listed to be matched |
Examples:
^A | matches any value starting with an A |
^[0-9] | matches any value starting with a digit |
^[0-9]+$ | matches any value consisting exclusively of digits |
^(beef|chicken)$ | matches values of either “beef” or “chicken” |
^([0-9]*) ([0-9]*)$ | matches two integer numbers separated by a space, and puts the first number into “Subexpression Matches List Name”{0} and the second into “Subexpression Matches List Name”{1} |
^N([0-9][0-9])[.]([0-9][0-9])[.]([0-9][0-9]) | matches N23.45.11 and puts 23 into “Subexpression Matches List Name”{0}, 45 into “Subexpression Matches List Name”{1}, and 11 into “Subexpression Matches List Name”{2} |
The Contains Regular Expression field can also include any number of special characters.
Characters can be expressed as regular characters but they can also include any number of control characters.
Special character sequences are interpreted as shown below:
Sequence | Description |
Ctrl+Shift+h (^H) |
Backspace (0x08) |
Ctrl+Shift+l (^L) |
Form feed (0x0c) |
Ctrl+Shift+j (^J) |
Newline (0x0a) |
Ctrl+Shift+r (^M) |
Carriage return (0x0d) |
Ctrl+Shift+i (^I) |
Tab (0x09) |
Ctrl+Shift+k (^K) |
Vertical tab (0x0b) |
Defining Special Characters
You can define special characters through the Text Editors. Click Open Text Editor from the parameter menu:
Text Editor
Enter characters using the shortcuts from the table above.
Note: To see tab characters, click the Options menu on the bottom left and select Show Spaces/Tabs.
Note that the matches can be either case-sensitive or case-insensitive, depending on how the transformer is configured.
The attribute name used to store the matching result. The default attribute name is _first_match.
Advanced
The optional name for the list attribute to store all matches. This parameter is left empty by default.
For example, if All Matches List Name was somelist and the string "Oct 15 1915; Apr 7 1964; May 21 1937" was searched with the regular expression \d{4}, all 4 digit strings would be matched, and we would have the following result:
somelist{1} = 1915
somelist{2} = 1964
somelist{3} = 1937
Note: List attributes are not accessible from the output schema in Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. Alternatively, AttributeExposer can be used.
The optional name for the list attribute to store subexpression matches. The difference between this list and All Matches List Name is the matches listed here are from capture groups, which are regex subexpressions contained by brackets. This parameter is left empty by default.
This parameter controls the order in which features exit a transformer.
When a transformer has more than one output port, features usually exit one port at a time. At times, it may be useful to keep the order that features arrived in, switching from port to port as necessary. This allows feature order to be preserved, though at a potential cost in processing efficiency.
Select a method for feature ordering.
Per Output Port (Default) |
Only preserve the input order of features as they occur within the group of features exiting a given output port. All features exiting an output port retain their ordering relative to each other (within the group), but not relative to features exiting other output ports. This option is generally the most efficient, where large chunks of features will exit an output port together (taking advantage of bulk mode). As features exiting different output ports may not be strictly output in the order they arrived, output ordering may be unpredictable. |
Across Output Ports |
Strictly preserve the input order of features, regardless of which output port they exit. Features will be output singly in the same order they arrived, switching from port to port as necessary. This option is generally less efficient as the processing gains of bulk mode are less likely to apply - however, feature order is predictable. |
- Output feature order may be controlled with the Advanced > Preserve Feature Order parameter.
- To replace substrings matching a regular expression in a string, use the StringReplacer transformer.
Additional Resources
Test regular expressions with the Regular Expression Editor in the Contains Regular Expression field’s context menu.
For more information on regular expression syntax, see http://perldoc.perl.org/perlre.html#Regular-Expressions.
Dialog Options - Tables
Transformer History
This transformer was previously named Grepper.
Keywords: Grepper
