RasterNumericCreator
Creates a numeric raster of specified size and resolution, with default cell values.
- Workspace testing
- Creating numeric raster placeholders
The RasterNumericCreator creates a single numeric raster feature, based on specified size, resolution, rotation, and interpretation type. Size may be defined either by number of rows and columns, or by extents.
Minimum and maximum cell values must be provided, and a Nodata value may optionally be defined.
The output raster feature may be generated with a choice of patterns, shown here on a 24 by 24 cell raster:
Single Value | All cells have the Max Numeric Value. |
Checkered Pattern | One set of cells is set to the Max Numeric Value, and alternating cells have values between the Min and Max Numeric Values. |
Checkerboard | An 8 by 8 checkerboard pattern is created, with alternating blocks of cells set to the Min and Max Numeric Values. |
In this example, we will create a numeric raster for testing purposes, enabling us to run and test a workspace before the actual data is available. A RasterNumericCreator is added to the workspace, and feature caching (A) allows us to view the raster as it exits the transformer.
In the parameters dialog, we choose Resolution Specification as Rows and Columns, and specify the size as 1600 by 1000 cells.
An Interpretation of Int32 with Min and Max Numeric Values of 0 to 13000 are appropriate for our test scenario, where the output raster will be a placeholder for a raster DEM. 13,000 is the highest expected elevation for the area.
The Data Pattern for the output raster is Checkered Pattern, which will provide a range of cell values to test against.
The output raster feature has the specified size, and one INT32 band. It is passed along to the next transformer and can now be used in the workspace.
Zooming in closely, the alternating cell values can be seen.
- To create an RGB raster in a similar manner, use the RasterRGBCreator.
Choosing a Raster Transformer
Working with Rasters
RasterCellOriginSetter | Sets the cell origin point within cells in a raster. |
RasterConvolver |
RasterExpressionEvaluator | Evaluates expressions on each cell in a raster or pair of rasters, including algebraic operations and conditional statements. |
RasterExtentsCoercer | Replaces the geometry of input raster features with a polygon covering either the extents of a raster or the extent of data within a raster. |
RasterGCPExtractor | Extracts Ground Control Point (GCP) coordinate system and point values from a raster feature and exposes them as attributes. |
RasterGCPSetter | Sets Ground Control Points (GCPs) on a raster, pairing cell positions with known coordinates. |
RasterGeoreferencer | Georeferences a raster by either known corner coordinates or origin, cell size, and rotation. |
RasterHillshader | Generates a grayscale shaded relief representation of terrain, based on elevation values. |
RasterInterpretationCoercer |
RasterMosaicker | Merges multiple raster features into a single raster feature. |
RasterPropertyExtractor | Extracts the geometry properties of a raster feature and exposes them as attributes. |
RasterPyramider | Resamples rasters to multiple resolutions, based on either number of levels or dimensions of the smallest output raster. |
RasterRegisterer | Transforms an image to minimize its difference with another. |
RasterResampler | Resamples rasters, based on specified output dimensions, cell size in ground units, or percentage of original, and interpolates new cell values. |
RasterRotationApplier |
RasterSharpener | Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
RasterSubsetter | Clips raster features using pixel bounds instead of ground coordinates, and optionally adds cells around the perimeter. |
RasterTiler | Splits each input raster into a series of tiles by specifying either a tile size in cells/pixels or the number of tiles. |
RasterToPolygonCoercer | Creates polygons from input raster features. One polygon is output for each contiguous area of pixels with the same value in the input raster. |
WebMapTiler | Creates a series of image tiles that can be utilized by web mapping applications such as Bing™ Maps, Google Maps™, or Web Map Tile Service. This is done by resampling rasters to various different resolutions and then splitting them into tiles. |
Working with Bands
RasterBandAdder | Adds a new band to a raster feature. |
RasterBandCombiner | Merges coincidental raster features into a single output raster feature, preserving and appending all bands. |
RasterBandInterpretationCoercer |
RasterBandKeeper |
RasterBandMinMaxExtractor | Extracts the minimum and maximum band values, palette keys, and palette values from a raster feature, and adds them to a list attribute. |
RasterBandNameSetter | Sets the band name of selected bands on a raster, making raster contents simpler to understand compared to band numbers. |
RasterBandNodataRemover | Removes the existing Nodata identifier from selected bands of a raster feature. Any values previously equal to the Nodata value are considered valid data. |
RasterBandNodataSetter | Sets a new Nodata value on selected bands of a raster feature. |
RasterBandOrderer | Specifies the required order of bands in a raster. Bands are reordered according to the input band indices. |
RasterBandPropertyExtractor | Extracts the band and palette properties of a raster feature and exposes them as attributes. |
RasterBandRemover | Removes any selected bands from a raster feature. |
RasterBandSeparator | Separates bands or unique band and palette combinations, and outputs either individual raster features or a single new raster feature containing all combinations. |
RasterStatisticsCalculator | Calculates statistics on raster bands and adds the results as attributes. |
Working with Cells
RasterAspectCalculator |
RasterCellCoercer | Creates individual points or polygons for each cell in a raster, optionally extracting band values as z coordinates or attributes. |
RasterCellValueCalculator | Evaluates basic arithmetic , minimum, maximum or average operations on the cell values of a pair of rasters. |
RasterCellValueReplacer | Replaces a range of band values in a raster with a new single value. |
RasterCellValueRounder | Rounds off raster cell values. |
RasterSegmenter | Partitions a raster image into arbitrarily sized groups of cells from the input image based on intensity differences in the input raster image cells. |
RasterSingularCellValueCalculator | Performs basic arithmetic operations on the cell values of a raster against a numeric value. |
RasterSlopeCalculator | Calculates the slope (maximum rate of change in z) for each cell of a raster. |
Working with Palettes
RasterPaletteAdder |
RasterPaletteExtractor | Creates a string representation of an existing palette on a raster and saves it to an attribute. |
RasterPaletteGenerator | Generates a palette out of the selected band(s) of a raster. The output raster will have the selected band(s) replaced by a new band with a palette. |
RasterPaletteInterpretationCoercer |
RasterPaletteNodataSetter |
RasterPaletteRemover | Removes selected palette(s) from raster features. |
RasterPaletteResolver | Resolves the palette(s) on a raster by replacing cell values with their corresponding palette values. Palette values with multiple components, such as RGB, are broken down and the individual values assigned to multiple, newly-added bands. |
Workflow Control
RasterCheckpointer | Forces accumulated raster operations to be processed, saving the state to disk and releasing resources to tune performance or assist with memory limitations. |
RasterConsumer | Reads raster features for testing purposes, including any accumulated raster operations. No additional operations are performed, and nothing is done with the features. |
RasterExtractor | Serializes the geometry of a raster feature into a Blob attribute, encoding the contents according to a choice of common binary raster formats. |
RasterNumericCreator | Creates a numeric raster of specified size and resolution, with default cell values. |
RasterReplacer | Decodes a binary attribute containing encoded rasters stored as Blobs, replacing the feature’s geometry with the decoded raster. |
RasterRGBCreator | Creates a color raster feature of specified size, resolution, and interpretation type, with default cell values. |
RasterSelector |
Vectors and Rasters
ImageRasterizer | Creates a raster representation of vector or point cloud input features, using the fme_color attribute over a solid background fill for vector features. Point clouds may be rendered using their color or intensity components. |
NumericRasterizer | Creates a numeric raster representation of vector or point cloud input features, where cell values are taken from the z coordinates of the input features and overlaid on a uniform background. |
MapnikRasterizer | Generates a raster from input vector and raster features, with fine control over symbolization and labeling, using the Mapnik toolkit. |
PointCloudOnRasterComponentSetter | Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location. |
PointOnRasterValueExtractor | Extracts the band and palette values from a raster at the location of one or more input points and sets them as attributes on the feature. |
RasterDEMGenerator | Produces a raster digital elevation model (DEM) by uniformly sampling a Delaunay triangulation generated from input points and breaklines. |
VectorOnRasterOverlayer | Rasterizes vector or point cloud features onto an existing raster. For vector features the fme_color attribute sets pixel color, and point clouds may be rendered using their color or intensity components. |
This transformer has no input ports.
One numeric raster feature, according to the specified parameters.
Resolution Specification |
Select the type of Resolution Specification:
Number of Columns (cells) Number of Rows (cells) |
When Resolution Specification is Rows and Columns, specify the number of rows and columns for the output raster. The minimum value for both rows and columns is one (1). | ||||
X Cell Origin Y Cell Origin |
Specify the origin for each cell. This can be used to specify whether each cell's data point is at the lower-left or center (or somewhere else) within the cell. | ||||
X Cell Spacing Y Cell Spacing |
Specify the spacing between cell elements, that is, the width and height of an individual cell. This must be greater than zero. | ||||
X Upper Left Coordinate Y Upper Left Coordinate |
Specify the coordinates of the upper left corner of the raster. Default is 0,0. | ||||
X Lower Right Coordinate Y Lower Right Coordinate |
When Resolution Specification is Extents, specify the coordinates of the lower right corner. | ||||
Rotation | Specify the rotation of the raster. Default is 0.0. |
Interpretation |
Select an Interpretation Type for the output raster. Choices include:
Min. Numeric Value Max. Numeric Value |
Specify the range of cell values to be used for generating the selected Data Pattern. |
Nodata Numeric Value |
Optional: Set a Nodata Value on the output raster. |
Data Pattern |
Select a pattern for the output raster:
Dialog Options - Tables
Not Applicable |
Not Applicable |
Dependencies | None |
Aliases | |
History |
Search for all results about the RasterNumericCreator on the FME Community.
