NetworkTopologyCalculator
Finds the connected lines that belong to the same network graph.
Network lines
Input Line features must be a topologically noded network with features connecting at line ends only. That is, all features must be split at junctions.
All connected lines are output through the Network port.
All non-linear features are output through the <Rejected> port.
Group Processing
The default behavior is to use the entire set of features as the group. This option allows you to select attributes that define which groups to form.
Process At End (Blocking): This is the default behavior. Processing will only occur in this transformer once all input is present.
Process When Group Changes (Advanced): This transformer will process input groups in order. Changes of the value of the Group By parameter on the input stream will trigger processing on the currently accumulating group. This may improve overall speed (particularly with multiple, equally-sized groups), but could cause undesired behavior if input groups are not truly ordered.
There are two typical reasons for using Process When Group Changes (Advanced) . The first is incoming data that is intended to be processed in groups (and is already so ordered). In this case, the structure dictates Group By usage - not performance considerations.
The second possible reason is potential performance gains.
Performance gains are most likely when the data is already sorted (or read using a SQL ORDER BY statement) since less work is required of FME. If the data needs ordering, it can be sorted in the workspace (though the added processing overhead may negate any gains).
Sorting becomes more difficult according to the number of data streams. Multiple streams of data could be almost impossible to sort into the correct order, since all features matching a Group By value need to arrive before any features (of any feature type or dataset) belonging to the next group. In this case, using Group By with Process At End (Blocking) may be the equivalent and simpler approach.
Note: Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order.
General
Linear input features that are connected will be assigned the same network ID in the Network ID Attribute.
Network Topology in FME
In order to successfully generate a network topology, some conditions must be met.
Lines must touch (be snapped) at an end vertex - first or last.
Lines must be split at junctions. The TopologyBuilder can automate this process, but will not consider z-values (and so may not produce correct results for overpasses/underpasses, for example.)
A junction at an interior vertex (not an end vertex) produces a complex edge, which is not supported.
Dialog Options - Tables
Transformer History
This transformer has been renamed from NetworkTopologyBuilder.
Keywords: Network, NetworkTopologyBuilder
Keywords: network networktopologybuilder
