AzureServiceBusConnector
Connects to Azure’s Service Bus using the Azure Service Bus SDK.
Receive and send messages from a queue or topic
- Interoperability with Big Data analytics platforms
The AzureServiceBusConnector connects to Azure’s Service Bus using the Azure Service Bus SDK.
Service Bus uses the AMQP 1.0 protocol. The connector supports sending and receiving messages.
More information about Service Bus can be found in the official Microsoft documentation.
The output of this transformer will vary depending on the action performed. Message data and metadata are presented as feature attributes.
After a Receive from Queue action, output features represent messages received from an Azure Service Bus Queue.
After a Receive from Subscription action, output features represent messages received from an Azure Service Bus Subscription.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Note: If a feature comes in to the AzureServiceBusConnector already having a value for fme_rejection_code, this value will be removed.
Credential Source |
Required for authentication. Using a web connection integrates best with FME, but in some cases, you may wish to use one of the other sources.
Account |
Available when the credential source is Web Connection. To create an Azure Service Bus connection, click the 'Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. |
Embedded Credentials
Service Bus Connection String | Available when the Credential Source is Embedded. The connection string is found in the Azure Portal Service Bus Namespace under Shared Access Policies. |
Action |
The type of operation to perform. Choices are:
Event Hubs |
The event hub to connect to. |
The remaining parameters available depend on the value of the Request > Action parameter. Parameters for each Action are detailed below.
Receive from Queue Options
Receive Mode |
Two message receiving options are available:
Delete on Receive |
If Yes, deletes the message from the queue upon receiving. If No, the message is retrieved but stays in the queue. The message will be available to receive after the lockout period. |
Batch Size |
In Batch mode, specifies the number of messages to read per batch. Default is 1. |
Receive from Subscription Options
Receive Mode |
Delete on Receive |
If Yes, deletes the message from the subscription upon receiving. If No, the message is retrieved but stays in the subscription. The message will be available to receive after the lockout period. |
Batch Size |
Send to Queue Options
Queue |
The Queue to send messages to. |
Create Queue |
If Yes, create the queue with the given name. A message will be logged if the queue already exists. If No, use the available queue. |
Payload |
The content of the message. This is often JSON, but can be any string, binary, integer or floating-point value. |
Message Properties |
Custom settable message properties. Any key value can be used, however the following keys are mapped to the respective attributes on the message.
Send to Topic Options
Topic |
The Topic to send messages to. |
Create Topic |
If Yes, create the topic with the given name. A message will be logged if the queue already exists. If No, use the available topic . |
Payload |
Count Messages Options
Resource |
The resource to count available messages. Either Queue or Subscription. |
The following attributes can be selected for inclusion on the output features. Each output feature represents a message that was either sent or received.
_payload | The message payload. UTF-8 string if possible to decode, otherwise binary or numeric. |
_properties | A key, value pair of message properties. |
_content_type | The settable content type of the message. |
_correlation_id | The settable correlation id of the message. |
_enqueued_sequence_number | The position of the message in the queue/subscription. |
_enqueued_time | The FME timestamp of when a message was added to the queue/subscription. |
_expires_at | The FME timestamp when the message expires. |
_lock_tocken | A uuid used to indicate the message has been received but not completed or deleted. It prevents other receivers from receiving the message |
_locked_until | The FME timestamp when the message will be unlocked so it can be received again. |
_message_id | The settable id of a message. |
_partition_key | The key of the partition the message is in. |
_reply_to | The settable reply to of a message. |
_sequence_number | The sequence number of a message. |
_subject | The settable subject of a message. |
_time_to_live | The FME timestamp of how long the message will stay in the queue/subscription. |
_to | The settable to of a message. |
Dialog Options - Tables
Dependencies | Microsoft Azure Account with the Service Bus Service |
Aliases | |
History | Released FME 2019.2 |
Search for all results about the AzureServiceBusConnector on the FME Community.
