Reprojects x and y coordinates stored as attributes from one coordinate system to another.
- Reprojecting coordinates stored as attributes (not geometry) to the desired coordinate system
- Adding additional coordinate pairs as attributes, in alternate coordinate systems
The AttributeReprojector accepts any feature. The user specifies the attributes containing x and y coordinates, and supplies both the source and destination coordinate systems.
The transformer reprojects the coordinates according to these selections, and updates the x and y attributes to the new values, overwriting the originals.
This transformer does not alter the feature’s geometry – only the values of the selected X and Y attributes (if they contain coordinate values) are changed.
Accurate results depend on the user’s correct selection of the source coordinate system.
Dynamic Coordinate Systems
Features may be reprojected to a dynamic Destination Coordinate System - that is, a local coordinate system that is created specifically for each individual feature. This is often used for tasks such as taking measurements or creating geometry in meters or other ground units, on data with geographic (latitude and longitude) coordinates.
There are two types available:
- _AZMEA_ (Dynamic Reprojection Equal Area) - Better for preserving area accuracy
- _AZMED_ (Dynamic Reprojection Equal Distance) - Better for preserving distance accuracy
In either case, the input feature is reprojected to a local coordinate system centered on its bounding box. Though all the output features will be centered on a common origin (with the exception of features located very near the poles) and appear stacked on top of each other, each one retains the specifics of its reprojection (and so original position), and can be safely reprojected back into a projected or geographic coordinate system.
Note that Z values are not considered, so areas or distances are best preserved for geometry at an ellipsoid height of 0 meters.
Note: To calculate and reproject to a single AZMED or AZMEA coordinate system that encompasses all input features, consider using the CommonLocalReprojector.
 Example: Reprojecting coordinates in a CSV file
                                                In this example, we start with a CSV file of drinking fountain locations. A CSV dataset has no geometry, but it does contain coordinates for the fountains, in a UTM projection.
The CSV features are routed into an AttributeReprojector.
In the parameters dialog, the x and y attributes containing the coordinates are specified accordingly, the source coordinate system entered (as UTM83-10), and the new destination coordinate system chosen (LL-WGS84).
The new coordinates are calculated and replace the existing attribute values. The transformer does not create geometry, it only supplies values.
 Example: Adding a new coordinate pair in an alternate coordinate system
                                                In this example, we start with a CSV file of drinking fountain locations, which has no geometry. It contains coordinates for the fountains, in a UTM projection. We want to add an additional coordinate system’s coordinates to it, to provide options for users who may not have access to software that will reproject it for them.
The CSV features are routed into an AttributeManager, and then to the AttributeReprojector.
In the AttributeManager, we add two new attributes, named x_LLWGS84 and y_LLWGS84. Using the Attribute Value column, we copy the current x and y coordinates (still in UTM) from the x_coord and y_coord attributes.
In the AttributeReprojector parameters dialog, the x and y attributes are set to the new (copied) attributes, and the Source and Destination coordinate systems chosen.
The output now contains both sets of coordinates - the original UTM and new LL-WGS84.
- FME has a Workspace Parameter, Reprojection Engine, that may be set to either FME (CS-Map) or Esri. This transformer will honor that parameter setting.
- This transformer does not do vertical reprojections. For vertical handling, consider using the CsmapAttributeReprojector.
 Coordinate System Support and Reprojection
| Looks up coordinate system names and definitions between FME’s internal format and common third-party and open source representations, storing the results as an attribute. | |
| Retrieves the name of the feature's assigned FME coordinate system into an attribute. | |
| Removes the coordinate system from features, without modifying geometry or coordinates. | |
| Assigns a specified coordinate system to features, without modifying geometry or coordinates. | |
| Assigns a specified local coordinate system to features, without modifying geometry or coordinates. |
 | Library |
| Reprojects x and y coordinates stored as attributes from one coordinate system to another. | FME (default) or Esri | |
| Reprojects one or more features to a local coordinate system centered on the bounding box containing all features. | FME (default) or Esri | |
| Converts a given angle from one coordinate system to another. | FME (default) or Esri | |
| Converts a given length from one coordinate system to another. | FME (default) or Esri | |
| Reprojects feature x and y coordinates from one coordinate system to another. | FME (default) or Esri |
 | Library (External Links) |
| Reprojects x, y, and optionally z coordinates stored as attributes from one coordinate system to another using the CS-MAP library. | ||
| Reprojects feature x, y, and optionally z coordinates from one coordinate system to another using the CS-Map library. | ||
| Reprojects feature coordinates from one coordinate system to another using the Esri reprojection library. | ||
| Great Britain Northern Ireland Republic of Ireland | Reprojects feature coordinates from one coordinate system to another using the Grid InQuestII engine from Ordnance Survey, for use in Great Britain, Ireland, and Northern Ireland. | |
| Sweden | Reprojects coordinates stored as attributes from one coordinate system to another using the Gtrans reprojection engine from the National Land Survey of Sweden (Lantmäteriet). | |
| Sweden | Reprojects feature coordinates from one coordinate system to another using the Gtrans reprojection engine from the National Land Survey of Sweden (Lantmäteriet). | |
| Reprojects coordinates stored as attributes from one coordinate system to another using the PROJ library. | ||
| Reprojects feature coordinates from one coordinate system to another using the PROJ library. | ||
| Switzerland | Reprojects feature coordinates from one coordinate system to another in Switzerland, using the Reframe library from the Federal Office of Topography (swisstopo). |
 Input
Input
                                                The features that contain the attributes you want to reproject.
 Output
Output
                                                Features with reprojected attributes as specified.
 General
General
                                                | X Attribute | Provide the attribute containing the X coordinate to be reprojected. |
| Y Attribute | Provide the attribute containing the Y coordinate to be reprojected. |
| Source Coordinate System | Specify the coordinate system of the incoming features. Coordinate systems may be explicitly selected from the FME Coordinate System Gallery, or provided by name via an attribute value or user parameter. |
| Destination Coordinate System | Specify the coordinate system to be reprojected to. Coordinate systems may be selected from the FME Coordinate System Gallery, or provided by name via an attribute value or user parameter. |
Using a set of menu options, transformer parameters can be assigned by referencing other elements in the workspace. More advanced functions, such as an advanced editor and an arithmetic editor, are also available in some transformers. To access a menu of these options, click  beside the applicable parameter. For more information, see Transformer Parameter Menu Options.
 How to Set Parameter Values
 Content Types
Content Types
| Special Characters | A set of control characters is available in the Text Editor. |
Dialog Options - Tables
                                                | Row Reordering
        | Enabled once you have clicked on a row item. Choices include:
| Cut, Copy, and Paste
| Filter
        | Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output. |
| Import
        | Import populates the table with a set of new attributes read from a dataset. Specific application varies between transformers. |
| Reset/Refresh
        | Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers. |
| Processing Behavior | |
| Feature Holding | No |
Search for all results about the AttributeReprojector on the FME Community.
