FTP Directory Modified
The FTP Directory Modified trigger monitors activity on an FTP server, and sends JSON messages about that activity, which can include adding, changing, and removing files.
The FTP Directory Modified trigger has two output ports. The success port () can send a message if the trigger polls successfully. The failure port (x) can send a message if the trigger fails to poll.
Note: Messages about changed files are based on file size. Therefore, if the size of a file after it is overwritten is the same as the initial size, a message may not be sent.
Output Keys
