Configure the FME Server Database on a Separate Database Server
Note: Complete this step only if you are configuring the FME Server Database on your own database server, and did not install the PostgreSQL database that is included with the FME Server installer. For more information, see Provide a Database Server.
To configure FME Server to use a separate database server, follow the steps below. You can configure FME Server with a Microsoft SQL Server, PostgreSQL, or Oracle database, running on either Windows or Linux.
- Database Configuration: Set up FME Server database tables and database users with permissions to access the FME Server database.
- Open the SQL Server Management Studio and connect to the SQL Server database engine.
- Open sqlserver_createDB.sql and run the script against the fmeserver database, as shown below:
- On the Object Explorer pane, expand the Security folder, right-click Login, and then select New Login:
- On the Login – New page, click General to open the page shown in the example below.
- At the Login name field, enter fmeserver.
- Make sure the option button is active for SQL Server authentication.
- In the Password field enter the password of your choice, and in the Confirm password field enter the same password again.
- Make sure the Enforce password policy is active. If not, click the checkbox to activate it.
- If required, click the checkbox for Enforce password expiration to clear it.
- At the Default database field enter fmeserver.
- On the same Login – New page, click User Mapping to open the page shown in the next figure.
- At the Users mapped to this login location, in the Map column click the checkbox to activate it and map the login name to the fmeserver database.
- At the Database role membership for location, notice that the fmeserver database is specified and check db_owner to assign that role to this database.
- Click OK to close this page.
- Connect to the SQL Server database engine and run sqlserver_createDB.sql.
- Open
sqlserver_createUser.sql
. - Look for the line that begins:
- Run the script.
- Install an Oracle database server.
- Obtain the Oracle Database JDBC driver. For more information, see https://www.oracle.com/technetwork/database/application-development/jdbc/downloads/index.html.
- oracle_createUser.sql – This script creates the FME Server database user and password that you specified during installation, and grants all required permissions to the FME Server database user. The password you specified during installation is encrypted and appears here as <<DATABASE_PASSWORD>>.
- oracle_createDB.sql – This script creates all FME Server related database packages, tables, indexes, views, and triggers.
- oracle_dropUser.sql – This script drops the FME Server database user and the database packages, tables, indexes, views, and triggers associated with the FME Server database user.
- Install Oracle SQL*Plus, if you haven’t already.
- Open Oracle SQL*Plus and log on as a user with adequate privileges, such as SYSDBA.
- User: SYS AS SYSDBA
- Password: fmeserver
- String: XX-ORACLE11G:1521/ORCL AS SYSDBA
- Create an FME Server database user as follows:
- From the SQL prompt, run the oracle_createUser.sql script by entering the following command:
- When an FME Server database user is created, you can connect to it by logging on again to SQL*Plus.
- User: fmeserver
- When connected to the FME Server database, run the oracle_createDB.sql script by entering the following command:
- Install the Oracle Client Tools, which includes SQL*Plus, if you haven’t already.
Run sqlplus and log on as a user with adequate privileges, such as SYSDBA.
For example:
sqlplus SYS/<password>@<Host>:<Port>/<service> AS SYSDBA
Create the FME Server database user. From the SQL prompt, run the oracle_createUser.sql script by entering the following command:
@”<FMEServerDir>/Server/database/oracle/oracle_createUser.sql”
The default TABLESPACE is the Oracle DB configured default. If the created user doesn’t have read/write permissions on the default TABLESPACE, you need to change the default TABLESPACE or create an appropriate TABLESPACE.
This command creates a TABLESPACE on the Oracle DB server called FMESERVER shown in the following example:
CREATE SMALLFILE TABLESPACE FMESERVER DATAFILE '/ORADATA/FMESERVER01.DBF' SIZE 100000K REUSE AUTOEXTEND ON NEXT 2048K MAXSIZE 1024M LOGGING EXTENT MANAGEMENT LOCAL SEGMENT SPACE MANAGEMENT AUTO DEFAULT NOCOMPRESS;
By default this command uses the TABLESPACE “FMESERVER” shown in this example:
CREATE USER fmeserver IDENTIFIED BY fmeserver DEFAULT TABLESPACE "FMESERVER" TEMPORARY TABLESPACE "TEMP";
When an FME Server database user has been created, you can connect to it by logging on again to SQL*Plus or by entering the following command:
CONNECT <UserName>/<Password>@<Host>:<Port>/<service>;
@”<FMEServerDir>/Server/database/oracle/oracle_createDB.sql”
- postgresql_createUser.sql – This script creates the FME Server database user and password that you specified during installation, and grants all required permissions to this user.
- postgresql_createDB.sql – This script creates the FME Server database.
- postgresql_createSchema.sql – This script creates all FME Server related tables, indexes, views, and triggers.
- postgresql_dropUser.sql – This script drops the FME Server database user.
- postgresql_dropDB.sql – This script drops the FME Server database.
- Install PostgreSQL SQL shell (psql) if you haven’t done so already.
- Open psql and log on as a user with the appropriate privileges:
- From the SQL prompt, run the postgresql_createUser.sql script by entering the following command:
- By default, the provided SQL script creates the FME Server database user and password that you specified during installation:
- Create an FME Server database.
- Quit psql and log on as the FME Server database user.
- Create the FME Server database schema as follows:
- postgresql_createUser.sql – This script creates the FME Server database user and password that you specified during installation, and grants all required permissions to the FME Server database user.
- postgresql_createDB.sql – This script drops the FME Server database and creates a new one with the required FME Server tables. By default this database is named fmeserver. Be careful when running this script because it drops the existing FME Server database.
– This script creates all FME Server related tables, indexes, views, and triggers.- postgresql_dropDB.sql – This script drops the existing FME Server database, which is named fmeserver by default.
- Install PostgreSQL Server if you haven’t already.
- Open a command prompt and change to the following directory, which contains the PostgreSQL SQL scripts:
Run the postgresql program with the postgresql_createUser.sql script:
psql -d postgres -h <hostname> -p <port> -f postgresql_createUser.sql
Run the postgresql program with the postgresql_createDB.sql script:
psql -d postgres -h <hostname> -p <port> -f postgresql_createDB.sql
Run the postgresql program with the postgresql_createSchema.sql script, as the user you specified during installation:
psql -U <username> -d fmeserver -h <hostname> -p <port> -f postgresql_createSchema.sql
- On the machine on which the FME Server database server is installed, open pg_hba.conf. For default installation directories of this file:
- PostgreSQL 10:
<PostgreSQLDir>\data\pg10\pg_hba.conf
- PostgreSQL 11: C:\Program Files\PostgreSQL\11\data\pg_hba.conf
- PostgreSQL 10:
- Change the following lines:
- Restart the FME Server Database service.
- Enable connections: FME Server connects to the database when it starts. Therefore, ensure that your database server is running and configured to accept incoming connections before FME Server is started. The database must allow connections over TCP/IP with all machines on which the FME Server Core and FME Engines are installed.
- Ensure that all installations of FME Server are running. For more information, see Working with the FME Server System Services.
Note: The specific way to set up database tables and user permissions on various production databases may differ depending on the available database tools and intended target platform.
It is assumed that SQL Server is installed.
One notation used is <FMEServerDir>
, which is the installation directory of FME Server. In Windows, this is typically C:\Program Files\FMEServer.
SQL scripts are provided to help with SQL Server database configuration. These SQL scripts are located in the <FMEServerDir>\Server\database\sqlserver\
directory of the FME Server Core machine.
Note: This directory refers to the machine on which the FME Server Core is installed (not the machine on which the database server is installed). To run these scripts, you must transfer this directory to the database machine, or reference it through a UNC path.
If you are upgrading, you should back up any job history you want to keep.
CREATE LOGIN fmeserver WITH PASSWORD =
The password you specified during installation is encrypted and appears here as <<DATABASE_PASSWORD>>. If desired, change the specified password to one of your choosing. Otherwise, take no action.
Before proceeding, you must provide the following:
<FMEServerDir> is the installation directory of FME Server. In Windows, this is typically C:\Program Files\FMEServer.
Note: If your version of Oracle requires a service name, rather than session ID (SID), for database connections, you must update the DB_JDBC_URL parameter in configuration file fmeDatabaseConfig.txt accordingly. For more information, see this FME Community article.
This section describes how to configure an Oracle database. You can configure the Oracle database from other Oracle database tools depending on your personal preference.
For an Oracle database configuration, various SQL scripts are provided to help.
These SQL scripts are located in the <FMEServerDir>\Server\database\oracle directory of the FME Server Core machine.
Using the Command Prompt
To use the command prompt to configure the database, follow these instructions:
In this example, the following parameters were used and entered:
@”<FMEServerDir>\Server\database\oracle\oracle_createUser.sql”
The default TABLESPACE is the Oracle DB configured default. If the created user doesn’t have read/write permissions on the default TABLESPACE, change the default TABLESPACE or create an appropriate TABLESPACE.
CREATE SMALLFILE TABLESPACE FMESERVER DATAFILE 'E:\ORADATA\FMESERVER01.DBF' SIZE 100000K REUSE AUTOEXTEND ON NEXT 2048K MAXSIZE 1024M LOGGING EXTENT MANAGEMENT LOCAL SEGMENT SPACE MANAGEMENT AUTO DEFAULT NOCOMPRESS;
By default this command uses the TABLESPACE “FMESERVER” as shown in the following example:
In this example, the following parameters were used and entered on the user interface:
Note: The preceding example assumes your user name and password are fmeserver.
@”<FMEServerDir>\Server\database\oracle\oracle_createDB.sql”
Note: If you drop the FME Server database and login user, run the oracle_dropUser.sql script.
Oracle SQL*Plus is a freeware client for connecting to an Oracle database. You can download it from the Internet using the following address:
http://www.oracle.com/technology/software/tech/sql_plus/index.html
For more information, see the Oracle web site at:
http://www.oracle.com/technology/sample_code/tech/sql_plus/htdocs/demobld.html
The instructions that follow describe how to configure Oracle for use with FME Server. These instructions describe using SQL*Plus for the database setup. Depending on your personal preference, you can also configure the Oracle database using other Oracle tools.
For Oracle configurations, various SQL scripts are provided to help with Oracle database configuration. These SQL scripts are located in the <FMEServerDir>/Server/database oracle/ directory of the FME Server Core machine.
PostgreSQL is an open source database that can be downloaded from the Internet. For more information, see the PostgreSQL web site at:
It’s assumed that PostgreSQL is already installed .
One notation used is <FMEServerDir>, which is the installation directory of FME Server. In Windows, this is typically C:\Program Files\FMEServer.
It’s also assumed that you have JRE 5 or higher and PostgreSQL database installed before you proceed further. If you want to use the JDBC driver, there are several steps to perform.
This section describes how to configure a PostgreSQL database. You can configure this database from other PostgreSQL database tools, depending on your personal preference.
For a PostgreSQL database configuration, various SQL scripts are provided to assist you. These SQL scripts are located in the following directory:
<FMEServerDir>\Server\database\postgresql
Note: The password is encrypted and appears in the script as <<DATABASE_PASSWORD>>.
\i '<FMEServerDIR>/Server/database/postgresql/postgresql_createUser.sql'
From the SQL prompt, run the postgresql_createDB.sql script by entering the following command:
\i '<FMEServerDIR>/Server/database/postgresql/postgresql_createDB.sql'
By default, the provided SQL script creates an FME Server database named fmeserver and grants all privileges on the database to the user.
From the SQL prompt, run the postgresql_createSchema.sql script by entering the following command:
\i '<FMEServerDir>/Server/database/postgresql/postgresql_createSchema.sql'
By default, the provided SQL script creates all FME Server related tables, indexes, views, and triggers.
This section describes configuring PostgreSQL from both the command prompt and a user interface, such as the PostgreSQL Query Browser and the PostgreSQL Administrator.
For PostgreSQL configurations, various SQL scripts are provided to help with PostgreSQL database configuration. These SQL scripts are located in the <FMEServerDir>/Server/database/postgresql/ directory of the FME Server Core machine.
Note: This script must be run as user fmeserver.
Note: If you drop the FME Server database and login user, run the postgresql program with the appropriate postgresql_dropDB.sql or postgresql_dropUser.sql scripts.
After Database Creation
host all all 127.0.0.1/32 md5
host all all ::1/128 md5
to:
host all all 0.0.0.0/0 md5
host all all ::/0 md5
What's Next?
